Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
A
Anonymous Posted on Jul 18, 2014
Hoover spinscrub 50 had a grinding noise and then stoped working
1 Related Answer
supershadowx
Denkichu
  • 507 Answers
  • Posted on Feb 23, 2017
SOURCE: My hoover spinscrub 50 leaks when i put the water tank on
seems like a rubber seal isnt setting right with the tank or the seal is damaged
1helpful
How do I check my hoover floormate deluxe spinscrub's filter and motor? Thanks in advance!!
The filter is at the top of the recovery tank (dirty water tank), should be replaced when dirty or odors occur. as to your motor, there is no way for an end user to remove any cover and check it. If you are experiencing noise, have it checked by an authorized service center.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
How can I get power switch to work on hoover spinscrub steam carpet cleaner?
Replace the switch.
http://www.ereplacementparts.com/hoover-f5914900-steamvac-with-clean-surge-parts-c-37315_37419_37425.html
2answers
Hoover spinscrub 50 smells like rubber burning
There are no belts lol. Its a carpet shampooer
Floormate noise
The motor sounds bad. Use the Hoover web site to locate a shop near you for warranty repair. hoover.com
2answers
Loud Grinding Noise
Take out the brush block and see if it will power on, if not then probably your motor has gone bad.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
