Question about Kodak EasyShare SV811 (8858946) Digital Picture Frame
My kodak easyshare digiital frame is 128 mb Will a 16 gb card fit the frame.
When the card is put into the frame, the pictures won't show. A 4gb card will show the pictures.
1 Related Answer
Anonymous
SOURCE: Hello, Frame is Kodak EasyShare P725 When I put 2
Try FAT32
Posted on Apr 30, 2011
Kodak EX 1011 does not recongnize memory card
On the contrary. The EX1011 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and the frame will not recognize it as a memory card. You need to use SD cards, 2GB and smaller.
Jan 31, 2012 | Kodak EasyShare EX1011 Digital Picture...
What size memory card does the kodak easyshare cx6200 take?
The internal memory for this camera is 8 MB.
The manual indicates using memory cards of size 8 to 128 MB, so this is an early SD memory camera, following the original SD standard. Do not try SDHC or SDXC cards. The camera will support a 1 GB card. It *might* support a 2 or 4 GB card, but since this is a 2 Mpixel camera, a 512 MB or 1 GB card will allow you to save thousands of jpeg format pictures.
Mar 01, 2011 | Kodak EasyShare CX6200 Digital Camera
Bought a 4GB SD card for my easyshare z700 camera. when I try to format it says to select "continue". when I select it loops right back to "memory card requires formatting, select continue". All the while...
The Z700 works with SD cards. Your 4GB card is actually an SDHC card (the HC stands for High Capacity) and will not work in the Z700. You'll have to stay with SD cards 2GB and smaller.
Jul 13, 2010 | Kodak EasyShare Z700 Digital Camera
Kodak easyshare M1093 refuses to format disk
The recommended card for your camera are those SDHC type or 2GB-16 GB SDHC card, try to use at least 2 SDHC card if this failed it means the memory card reader of your camera is already defective. Just in case this will happen try to contact Kodak at 1 800 235 6325 ext 12.
Feb 09, 2010 | Kodak EasyShare M1093 IS Digital Camera
Kodak EasyShare SV811 won't read SD / HD card
Compatible Card-Slots : SD/MMC; xD; CF;Memory Stick; Microdrive; USB
You might have too much data on the SD card. Try with less pics onto the card.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jun 25, 2009 | Kodak EasyShare SV811 (8858946) Digital...
How do I get music into SV1011 digital Picture frame
There is no internal memory on your frame. Therefor you must transferre the music onto the SD card and then it will play from your frame.
Contact KODAK:
Mar 09, 2009 | Kodak Digital Picture Frame
Just bought a 4gb kodak memory card for my kodak easyshare cx7530 camera.the shop assisant told me it was compatible. it wont format..
No way-that model will not support a 4gb card-yes it may fit but camera is to0 old for newer sdhc cards-go back to 1 or 2 gb max and no problems! 4gb only work on cameras within last 2 years
May 23, 2008 | Kodak Cameras
Kodak EasyShare SV811 (8858946) Digital Picture Frame Logo
75 people viewed this question
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
