Disk try keeps ejecting
This is likely the same issue occurring when the disk tray will not open either. Suspect your drive belt is worn and requires servicing. This is best done by an xbox servicing agent. Not too expensive. I have been suffering with a tray that will not open for over 2 years now, however, I am able to fix it simply by ensuring a disk is always left in the tray. It only fails to open if there is no disk in the tray. Even then, I can open it by lifting slightly with a paperclip.
SOURCE: Disk tray ejecting
Have you got the xbox stood up as in the picture. If so, position it lying flat (so the cd drawer is horizontal) and then try it. If this works, I think it is just general wear and tear on the mechanism.
Rgds
Tony W
SOURCE: Xbox 360 disk spins while ejecting
i had this same problem, so i figured, "what the hell?" i might as well open the dvd drive up and clean it out. so i looked for how to video for taking apart my 360 and opening the dvd drive on you tube( this voids your warantee of course) and i cleaned all the dust out with compressed air and swabs dipped in alchohol. this worked for me so i hope it works for you.
SOURCE: It takes 3 or more tries to load a game on our
First check to see if the tray has closed compleatley
by waching the green blinking light on the power button . If the light continues to blink evan after the
tray has shut, that means the close switch has not
engaged . Eject the tray and then as it's closing give
it a firm push just as it closes to force it to engage
the close switch.
If that's not the problem then it's more then likley
you have a weak laser. They cost 20.00-30.00 new,
and there not that hard to replace .Or you can have
a shop swap it out for around 70.00-80.00
If you need more info, just ask.
Rob
SOURCE: disk tray is not spinning
The way to fix this is to open the disk tray and blow inside for about thirty seconds getting the dust out of the way of the laser also blow across the disc tray and the surface of the disk. Then keep closing and opening the tray and it will start to read hopefully. if this does not work go out and buy a disc cleaner. it looks like a disc with sponges on it and when you insert it into the console it cleans the inside for you. Sources: i am going through it right now internet my personal experience
SOURCE: my xbox360 keep saying open tray and it is not
the xbox 360 disk reader is low on power so try to go get it fix by the store you bought it from or try to do it on your own hands like going on to you tube if you dare risking the chance of warrenty
