It says check with IPTV server
I just thought I would post this solution here after I spent several days and hours on the phone trying to get my Samsung Smart TV to connect to the internet. After having the television for 2 years with not problems at all, suddenly it would not connect to WiFi. The last tech at Samsung that I spoke with knew exactly what to do and my TV was back working and connection to the internet within a few minutes. He told me to reset the DNS to 8888.
Detailed instructions for the computer challenged community such as me: Best IPTV Service Providers
On your TV remote, go to Menu, Settings, Network
Next select Network Settings, Start, IP Settings
Then select DNS mode and make sure the green check is on "manual"
Enter 8 8 8 8 and OK
Bingo, instant internet
(note - I also was told to click on Samsung Smart Hub in upper right corner. I had reset my TV and it needed to update and add back my programs)
The easiest way to check this is to; enter the IP address of your router into the URL bar at the top of your browser, on phone, tablet or laptop. For Virgin Media and Sky users, it's 192.168.0.1. Some networks are different though, so Google it if you're with TalkTalk or someone else. Then, log into the router settings with the password - NOT your wifi password, but a specific one for the settings. It's usually on the bottom of your router, tucked away in the corner! Finally, if you've got a guest network switched on, you should be able to see a "Modify Guest Network" option or something similar, potentially in Advanced Settings. Here, just switching the Guest network off is the simplest way to make sure you don't connect to it. You can see who's connected to what, but it's complicated and a bit of a nightmare to do, so this is the easiest way. Hope that helps pal! Meilleur Abonnement IPTV
Im going to make this very easy for you.... follow this link I have posted your problem will be fixed http://www.youtube.com/watch?v=SXB01AM_tIs
If you need further help, reach me via phone at https://www.6ya.com/expert/timothy_c6f309c0f75b6f43
Contact the net service provider. Gopakumar Gopalan Google
