The thermostat? If your thermostat works normal, it should switch off the heater when the temperature is reached. Perhaps there is a last security, when it really gets to hot it will trip and you have can't use it till that is repaired. Perhaps you replace the thermostat. Or if a new thermostat is almost as expensive as a new fryer, buy a new fryer.
SOURCE: problems with fryer
your problem is the thermostat is bad.the reason it shuts down is that it trips the hi limit.the hi limit is a saftey device that shuts the system down so the oil doesnt get too hot and catch on fire.remove all the oil from the tank and you should see 2 skinny metal bulbs one is the hi limit bulb the other is the t-stat bulb,make sure they are secured to the bracket.if the t-stat bulb isnt you will also have this issue,simply reattach it.let me know.
SOURCE: Cecilware Fryer electric
you have a bad high limit the range on this should be around 600 degrees.
