IF you sidekick 3 screen is blank then the lcd needs to be replaced. Replacing the Sidekick 3 LCD screen is pretty easy and cost about 25 dollars if you buy it from ebay.
Your phone's LCD is damaged by some reasons (could be the heat produced while charging) or is loose.
If ot is still in place,the wayto have it back is to buy a new LCD. A ratr for this will be mush appreciated...
Does the lcd screen have a glow to it ? Or is it really dim if u get real close to screen u can see images moving ?
it it has a glow to it you panel lighting is fine but you control board is bad. If you have a dark screen and see faint images you panel back lighting is out u can check the power with a meter at the connection to inverter board on panel.
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
