What is the power supply resistance value of kv-sw25m50 of R 603 /R 622 SONY TV
You should download the repair manual to this set to know more about this. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
SMPS [Power supply] circuit diagrams to many popular brand TVs are given. It cannot be attached here by this window.
SOURCE: Sony wega model: kv-32FS120 doesn't turn on
Check your power supply board and resolder the pcb, check the switching diodes and zeners.
SOURCE: Thermistor resistance value on Sony KV-27S42
180358641 is correct replacement of THP601, Schematic (Service Manaul) is available on charge basis, have nice day!
SOURCE: sony kv-32xbr48 tv won't turn on
You need to check the horizontal drive transistor. This circuit provides the high voltage and other voltages needed for the television.
Jerry
SOURCE: Sony TV KV-32v15 Dead Power Supply
you should of recived a 0.01ohm resistor it is wite and sayes sony on it.
its a flame proof resistor that needs to be the very same
look for it on the pcb test it its probly open right.
ask them to send you the right part.
regards,
daniel.
SOURCE: sony color TV model kv-c29 11d blown power supply ic and transist
There should be circuit designations printed on the PC board. Without those, there are too many possibilities to give you anything useful. Can you provide those please?
Thanks,
Dan
