I have a 2014 dodge ram pickup with xm version of sirius xm. In northern canada xm signal is horrible bit sirius works flawlessly. Is there a upgrade to switch to sirius signal without adding a stand alone unit.
John
  • 509 Answers
The 2012 Dodge Caliber had a Sirius radio instead of XM - BUT - you will have to check if it has a "FAST" or a "SLOW" "BUSS SPEED" - that is very important that the radio you replace it with has the correct buss speed. Sirius will only work a little while longer as they are eventually going to phase out their overhead satellites for a geostationary satellite like XM. XM has the better sound than Sirius - if you can receive them. If you can't find a factory replacement from 2012, then BestBuy still sells a Stratus Sirius radio - and you can probably even fish-out the antenna wire that you already have for use with the plug and play add-on Status. Good luck - let me know if you have more questions.
Posted on Aug 01, 2014
1 Related Answer
catdaddyfm
SOURCE: I have a 2007 dodge ram pickup with sirius already
Hit eject button and clock button at same time. Ur Id number will show up. It will only show 4 numbers at a time. Hit seek button 2 more times to get the rest of the numbers
Posted on Feb 09, 2011
Need to know how to find radio id for xm in my 07 murano
Search Results
Find your Radio ID ' SiriusXM Canada
www.siriusxm.ca/help/find-your-radio-id/ Tune to SiriusXM channel 0 to find your ESN / Radio ID For most radios, the ESN / Radio ID will be displayed by tuning to Ch. 0. People also ask How do I find my radio ID ESN or SID?
What is Sirius Travel Link service?
Can you install Sirius radio in a car?
Can you get XM radio in your home?
Feedback
Find Your Sirius Radio ID - Sirius XM
https://www.siriusxm.com/help/findsirius Tune to Ch. 0 or select the MORE button on the touch screen. Then select Sirius Travel Link, then the Sirius button and the Radio ID will display. Starting in MY13 - XM Band Radios (VP1,VP2,VP3,VP4): (ignition on/radio on): Tune to Ch. 0 and the Radio ID will display.
How do I find my Radio ID (ESN or SID)? - Sirius XM
https://listenercare.siriusxm.com/...id/.../how-do-i-find-my-radio-id-%28esn-or-sid%2... Most radios will display the Radio ID (ESN or SID) when you tune to channel 0. If this doesn't work on your radio, click here to find your radio listed and follow the ...
How to find the I.D. number to activate the XM radio? - Nissan ...
forums.nicoclub.com > Technical > Nissan Audio / Entertainment / Security Aug 6, 2012 - t>Hello, I just bought a 2007 M35X and wanted to transfer the xm from the old car to the new one,I called xm and they ...
XM Losing it's Radio ID - Nissan Murano Forum
www.nissanmurano.org > ... > Model Specific Discussions > 2nd Gen (2009 - 2014) Apr 17, 2015 - I'm driving along and I think I'm just switching modes from regular radio to satellite. ... I know sometimes with my 03 XM seems to take a bit longer to load and I get a message about "loading" that can ... Old 04-27-2009, 10:07 PM Thread Starter. Satellite radio singup - Nissan Murano Forum
Nov. 6, 2015
Nissan Murano Forum - XM question
Jun. 30, 2011
Help needed / XM RADIO for a 2003 Nissan Murano - Nissan ...
Mar. 17, 2008
More results from www.nissanmurano.org find radio id for xm in my 07 murano Google Search
Jun 24, 2018 | Audio Players & Recorders
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
Jun 19, 2014 | Delphi Roady XT XM Radio Receiver
HP Mini 110 disconnects frequently from the network connection
Auto Tech: SiriusXM Satellite Radio
It seems like satellite radio has been around Canada forever now. Virtually every new vehicle sold here incorporates a satellite radio option although some even include satellite radio standard. May it be Sirius or XM, satellite radio offers drivers numerous radio channels which are accessible virtually anywhere in North America-ideal for international calls trips.
For anyone unaware of satellite radio, it is really an audio service available either inside your vehicle, with your mobile device, or online. The plethora of programming and quality of sound is different from station to station, and in some cases from song to song. Some songs be understood as there're being streamed throughout the internet and some could be seen as an audio DVD being took part in the car's built-in system. In addition to the various theme-based music channels, there are news, talk, and sports channels.
Satellite radio wouldn't actually arrived at Canada until 2005 when both XM and Sirius began offering it to us Canucks. Individuals who regularly employ this service, or keep pace with industry trends, knows that Sirius and XM merged in north america in 2008 and brought their services together. In Canada however, things were different. Sirius Canada and XM Canada failed to initially agree to the merger because of differing views regarding who should get what percentage from the company. But, a contract was reached and on April 12, 2011 SiriusXM Canada was officially formed.
Oct 23, 2012 | HEWLETT-PACKARD HP Mini 110 101Inch Mobile...
I have a 2007 dodge ram pickup with sirius already built in. When I hit the sat button it is on channel 184 and there is no sound. I cant change the channel and the volume control will only let me turn it...
Jul 07, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
I have a 2009 Dodge Ram pickup with factory sirius radio. When I put my cab over camper on it I lose the sirius radio signal. Is there a external antenna that will work with setup . I can mount it on top...
We had the same issue with our 2007 Dodge Ram truck. We use an external antenna when we have the camper on. You can buy these at various places on line. Get the car antenna not the home antenna. It magnetically mounts onto the truck so we put it on our hood and routed the antenna wire through the passenger side door. Our satellite box is behind the glove box. Remove the glove box and look up in the cavity. We were able to just unplug the factory antenna and plug the external antenna in. It's easy to switch back too. Just be careful with the antenna wire because it's fragile and any little bit of damage makes it useless.
Jul 04, 2010 | Sirius Satellite Radio Receiver
Antenna interface - Sirius to XM, Dodge
connector should fit - provided that there is ONLY one connector for the SatRad and not two.
You might have to trim off some yellow, or pink or green plastic, but the metal connector should fit.
Jan 24, 2010 | Terk XM Commander Satellite Radio Receiver
On a 08 RAM with factory Sirius, can it be
No it will not work... I have tried it
Sep 21, 2009 | 2008 Dodge Ram Pickup 1500
Sirius radio reset on dodge ram 2008
I have the same problem. When Sirius sent me a new "update" signal, I lost more channels. They don't have any idea. Did you figure out how to reset?
Oct 25, 2008 | Sirius Satellite Radio Sirius Starbase...
Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Apr 08, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
199 people viewed this question
Ekse
 Grubhead
Grubhead
