The fixing screw that holds the element in place is behind the fan, so it looks like the fan has to be removed to access the screw. How do I remove the fan?
SOURCE: Changing an element on the main oven - Neff U1721 Double oven
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Plz rate my solution.
Thanks.
SOURCE: unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Thanks.
SOURCE: Replacement of fan oven element on Nef U1721
Hi Steve...yes, these are a pain! Remove the centre fan nut (which is anti-threaded) then lever off the small locating washer underneath. If you are lucky, you will be able to now pull the fan blade off of the motor shaft. However, very often they won't budge!. If you try to knock it off, it is so easy to damage the fan motor (about £80!!). It is possible to leave the top bracket screwed to the oven and unclamp the element from it. I have come across three different typed of clamps so far. One is very easy to do. You can then remove the clamp from the new element and once the element is in place, use the old clamp. It's a fiddle but quite do-able. I have also come across these where the top clamp has been previously removed altogether by engineers on previous repairs! Hope this all helps a little....
SOURCE: replacing the element in a NEFF U1721 but having trouble
To rtemove the nut, hold the fan blades,and at the same time undo the securing nut clockwise as though you were tightening it, as it is a left hand thread, and vice versa for tighteming it again
Please rate mhy solution.
Thankyou..
