Question about Puma Drift Cat 4 Material Story Mens Shoes Black/Limestone Gray : 13 D - Medium
What is concrete lsm material? - Puma Drift Cat 4 Material Story Mens Shoes Black/Limestone Gray : 13 D - Medium
  • 18,342 Answers
The actual term is C L S M that means Controlled Low Strength Material. It is a method of making concrete that is used to fill in areas where compacted dirt would normally be used but the risk of sinking dirt would be a danger.
Posted on Aug 10, 2016
How many sand and stone and cement do you need or cubic meter of concrete
A concrete mixture ratio of 1 part cement, 3 parts sand, and 3 parts aggregate will produce a concrete mix of approximately 3000 psi. (20685 kpa)
Sep 21, 2018 | Building Materials
Is it posiible to level a concret slab after its set
Self Leveling Concrete Overlays The Concrete Network
This will correct a small correction of a about 1/4 inch. Other than that If its not level when poured it will be not level.
Jul 30, 2017 | Building Materials
If I clean up concrete contaminated by a post-1987 spill pursuant to state clean-up standards, can I continue to use the concrete? If not, what are the requirements?
You may use non-liquid materials such as concrete that were contaminated with PCBs $50 ppm provided the materials are decontaminated in accordance with a PCB disposal approval, or an applicable PCB spill cleanup policy, . The decontamination standard for concrete is <10 µg/100 cm² and requires that cleanup be initiated within 72 hours of the spill. If the state cleanup met these standards, you may continue to use the concrete. http://www.qjpcb.com/ Skype : wang.michelle35
Jun 29, 2016 | Office Equipment & Supplies
definitely not a television question
commercial or residential ?
If clean up was done to state regs that concrete is good for any use
just in case
define contaminated
hazardous , carcinogenic ,nuclear, bio hazard
solid concrete slab poured post 1986 will have reo
if sound condition can be used, painted over, carpeted .sealed , tiled.what ever
if cracked up due to demolition
still ok to use for land fill or other rubble type back fill
Jun 17, 2016 | Televison & Video
There are stains at the expansion joints on sidewalks that appear to be from weed/grass exterminator, not rust from well water.
Weed exterminators are pretty much clear and do not stain concrete or clay brick materials . So I doubt it has anything to do with any weed extermination treatment and I have used many of them.
Once a true stain is embedded in concrete it is extremely difficult to remove because concrete is a porous material. Power washing will not remove real stains no matter how much you clean it. This stain will most likely be coming from below the concrete and is leaching up to the surface when it rains enough. Most likely if you do remove it you will find it comes back.
I would try soaking the affected areas with a very concentrated mix of bleach and water but not if the concrete has been coloured in one of the darker tones used. Any of the very pale colours will be ok.
Jan 28, 2016 | Masonry Tools
How do I install my smart scan mouse
computadora prendida insertar la conexion usb en algun puerto usb colocar el disco de instalacion en la unidad dvd y esperar a que la computadora lo instale ...listo
Jun 20, 2013 | LG Lsm-100 Mouse Scanner
How to get rid of diesel oil stain on concrete floor? Last week, a leakage happened from the nozzle of the diesel tank after some sloppy maintenance works on the nozzle. The diesel dripped onto the...
If detergent and scrubbing is not working try a solvent ... but if that does work directly on the stain go the next step and create a poultice by saturating an absorptive material (such as kitty litter or sawdust) with a strong solvent (acetone, xylene, lacquer thinner, or MEK) and then smearing the material over the stain. Cover the poultice with plastic, and let the process of osmosis take over. The solvent will break down the oil, and the absorptive material will suck it out of the concrete. Part of the challenge with oil related stains in concrete is that the material has migrated below the surface into the concrete. The poultice process does takes time and may not be cost-effective or practical for removing large stains.
Jan 14, 2018 | Plumbing
How do you fix a dip and crack in garage concrete? Our garage has a crack and is dipping down.
The highway department fixes this by drilling a hole and then pumping concrete under the concrete until it lifts up.
I suggest you contact local concrete company to see who does this type of pumping. I've seen them fix driveways.
Don't know how much it costs.
Oct 08, 2010 | Garden
Puma Drift Cat 4 Material Story Mens Shoes Black/Limestone Gray : 13 D - Medium Logo
291 people viewed this question
Top Puma Sport & Outdoor - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Puma Sport and Outdoor - Other Expert? Answer questions, earn points and help others
