Question about HP PSC 750 All-In-One InkJet Printer
Printer/computer connection For some reason, my printer got disconnected with computer, all cables were in place, but when trying to print from website/wordpad/notepad, it failed to print, the printer itself is fine, i've done a self test report. But i continue getting hp psc disconnected status.I've tried to uninstall and re install the program but still not working, please help !!
Posted by suri17 on
Anonymous
  • 734 Answers
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Posted on Dec 04, 2008
My printer X5270 has lost connection. In the properties field of the printer, under the General tab the location field is blank and under the Ports tab a check is placed by the USB...Virtual port for USB....
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nb3gkh. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 19, 2011 | Lexmark X5270 All-In-One InkJet Printer
My dell 924 printer has stopped working. I get an error message that there is no USB connection. All connections & USB cable are fine. For some reason this printer is no longer on a USB port - have...
Hello.
It sounds like a issue with the hardware inside the printer. if possible try the printer on another PC, or try another USB Cable. Sometimes the cable can appear fine but can have small breaks inside it. You can also try your current cable on another persons printer to rule out the cable.
If you can not get the printer working on another persons computer I would suggest replacing it. it is cheaper than getting a tech to fix it.
Regards GM
May 27, 2011 | Dell 924 All-in-One InkJet Printer
I refilled the ink cartridges then i placed them back in the printer but it does not print from the computer though i can photocopy. please help
Assuming that you were printing correctly before you replaced the cartridges, I would try disconnecting the USB cable from your machine, rebooting, and once the machine is back up - replug the USB cable. That should reestablish the connection with your printer.
May 02, 2011 | HP PS C4780 All in One InkJet Printer
Says that it offline. will do everything except print
There are only 2 reason when printer says offline.
Ist. When computer does not communicate to printer and this is happen because usb cable not plugged in from printer to computer properly or its loose. If use cable already plugged in properly and try to plug the usb cable in a different port in your computer and then restart the computer. and if you are using wireless printer and wireless connection on printer is disconnected then Run the wireless printer setup again by printer disk.
if issue still persist then follow step 2.
IInd. Go to Start>>printer and devices>>here you will have your printer>>right click on it from your mouse and left click on Use this printer online
Mar 26, 2011 | Office Equipment & Supplies
I've had this HP printer for years with no problem using it most days. just plug it in when i want to print. but for some reason it has just decided that windows does not recognise this USB device. i have...
Disconnect the power cord from back of printer
Disconnect the USB cable from PC
Turn off your PC
Disconnect the power cord from wall outlet
wait for 10 minutes
Reconnect the PC Power cables
Power on the PC
When you see the PC desktop
Re-connect the Power cable to printer
Re-connect the USB cable of Printer to PC
This should resolve your issue
Sep 25, 2010 | Office Equipment & Supplies
Hi, i had this microline 390 turbo for quite some years and today, it's been a little weird. It keep printing for no absolute reason and what it's pringing are characters that seem to be encoding...
disconnect the LPT cable, and try a usb cable, the wierd printing should stop while the cable is disconnected. I'll be willing to bet there is something trying to print or poll the printer from the computer. that is causing the random characters. check to see that there are no other printers configured g to print/connect to same LPT1 port, from an old printer installation. (thus switching to the USB cable). Be also sure to download the latest drivers for your operating system for the OKI, from OKI's website
Aug 27, 2010 | OKI MICROLINE 390 Turbo Matrix Printer
I have a printer HP DJ 5940 and i have a problem with my connection. in status the printer says ready but when i try to printtest page says test page faild to print and i can't print. Any idea Manolis
Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
Aug 07, 2010 | HP Deskjet 5940 Photo InkJet Printer
The printer prints a test page everytime i turn the printer on
I had the same problem and it was driving me crazy until I did this. Please follow exactly and IN ORDER.
(You may now reconnect the printer to your computer via the USB cable.)
COURTESY:LILBLUEMIFI- A FELLOW EXPERT
Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that would be changing settings used by the driver. Click ok.
Jan 26, 2010 | HP PSC 1510v All-In-One InkJet Printer
I have reconnected my HP PSC 1315 to my printer, however, I cannot get the printer to work. Can you please help me? The printer will not do anything. I have received a print test after I installed the...
Hi melovesjags:
Try these steps.
Does the product
print from the
computer?
Connect the parallel
cable or USB cable to the
product and the
computer. Use a wordprocessing
application to
send a print job to the
printer.
The cable is not
connected correctly.
Reconnect the cable.
An incorrect printer driver
is selected.
Select the correct printer driver.
Other devices are
connected to the parallel
or USB port.
Disconnect the other devices and try again
to print.
There is an LPT port
driver problem.
Reset the computer port settings. See your
computer user guide for instructions.
The formatter has failed. Replace the formatter.
Hope these help
Jul 06, 2009 | HP PSC 1315 All-In-One InkJet Printer
When printing from the computer a piece of paper became jammed inside the printer; this has been removed but the printer still won't print even though the USB cable is securely in place.
the printer maybe still jammed. try to turn off the printer and disconnect it from the pc.
then turn on and connect it again.
if this not work, you can reset the printer somewhere.
CS.
May 18, 2008 | Computers & Internet
HP PSC 750 All-In-One InkJet Printer Logo
51 people viewed this question
Ekse
efs_perpends
efs_perpends
