Question about ULINE U Line 3000 Series 3018CLRS41 20" Built-in Undercounter Ice Maker with 30 lbs. Ice Storage, 60 lbs. Daily Ice Production, Frost Free, Clean Indicator Alert and Drain Required: Stainless Steel, Left Hinge with Pump
Why isn't my U-Line 3018CLR making ice?
The machine has only been in use 5wks and just quit making ice yesterday. The water runs down the ice mold but doesn't freeze, so at the end of a cycle there is no ice to dump (U-Line refers to this as the "harvest"). Then the water starts running again for the next cycle, rinse, repeat. The troubleshooting section of the product manual doesn't address this issue, what could it be?
Posted by Amy Paul Drinkwater on
Lawrence Oravetz
  • 10,548 Answers
Isn't it obvious the compressor isn't running to freeze the water? Make sure the thermostat is working.
Posted on Jul 17, 2014
Testimonial: "The "expert" was rude and obviously has no experience with the U-Line 3018CLR."
  • Amy Paul Drinkwater
    Amy Paul Drinkwater Jul 17, 2014
    No, actually, it's not obvious. If it were I wouldn't be asking. The manual also has no information regarding the location of the thermostat.
    Amy Paul Drinkwater Jul 23, 2014
    Appliance repair person confirmed that it's a coolant leak inside the sealed system and the machine will be repaired or replaced under warranty.
Refrigerator icemaker repair
The ice maker does its own thang. All it needs is power and a good water valve to supply the water. Also you paid the water bill helps too. Anywho when the temp in the ice maker mold drops below 25f the harvest cycle begins. The mold heater is activated and loosens the ice. When the ice starts moving the heater shuts down and the motor carrys over and drops the ice. The ice maker then asked for and gets water from the water valve. So what goes wrong? Watervalve solenoid burnt out, water valve dripping like a faucet make a stalagmite in the fill tube blocking fresh water to ice mold. If that is ok then something inside the icemaker went haywire, replace it. When replacing the ice maker replace the watervalve. Note: if temp inside icebox freezer does not get to 25f any ice maker new or existing ain't gonna make ice. Be sure to clean the coils down by the compressor and the kickplate so the maximum amount of airflow is running down there and make sure the cardboard panel back there is in place.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 26, 2013 | Dryers
Need info on how to hook up ice maker lines
OK the ice maker is the boss. It calls for water. Nothing else in the ice box controls the ice maker water but the ice maker itself. How? Fancier models use capacitance of ice mold to correctly fill the ice mold. On board intel monitors the temp of the ice mold by sending power through it and checking for differences in capacitance in the mold. When it hits the sweet spot it monitors the temp till it temps inside the mold determine ice is there and kicks in the harvest cycle. Older styles simply put a measured amount of water into the ice mold at the end of each harvest cycle. You gotta first run a water line to the water valve and then run a line from the water valve up to the Ice Maker fill spout behind the ice box. Nothing to it.
May 02, 2010 | Refrigerators
KitchenAid ice dispenser tray is dry - not working
Put some water in the ice mold is what I would try. wait and see if the ice maker harvest a batch. If it does drop a batch but no more then the water valve is probably shot. The ice maker itself controls the water. It does this by filling the ice mold for 7.5 seconds. Here is your Ice maker repair manual and some repair photos along with a pictorial which snows how to check the water valve.
Ice maker quit making ice
Apr 05, 2010 | KitchenAid KSRS25IL Side by Side...
The icemaker and water dispenser will not dispense water or ice
Hi
Many top-freezer ice makers have very similar ice makers that are pretty easy to diagnose. Side by side refrigerators have a variety of ice makers so I’ll start with the more common top freezer units. If yours makes crescent shaped ice cubes this will probably be relevant to your unit.
These ice makers have a metal wire bail or wand that senses if the ice level is too high. This sensor stops the ice maker from making ice that would overflow the catch bin. Check to make sure this sensor isn’t obstructed or locked at the far end of its travel. In normal operation the sensor wand should be resting against the ice maker. As it begins a cycle the wand sweeps across the catch bin and will be stopped if ice has risen too high. The same wand can be locked in a position at the far end of its travel to disable the ice maker. This is the most common cause of no ice. This may be what you meant by "made sure the tray was set right and arm was done"
If you have a different type of ice maker just spend a few minutes watching it operate or examine the non-operating unit. If you have a neighbor with a similar unit take a look at theirs. Many have a front cover that easily pops off giving access to the internal works. Listen as you watch to hear solenoid valves open, water flow, etc.
Make sure you look for any other interlock switches that would stop ice making if the tray were removed, the door was opened, etc.
You’ve already checked the water line, I’ll assume you disconnected it and tested for water flow or it was a translucent line and that you saw water in it. While you could do further tests on the water inlet valve, it’s probably easier just to verify that water is making it into the ice mold. If no water or ice is in the mold then you need to check the inlet valve or check the timer’s water switch. If there’s water or ice in the mold then your water supply is working and we need to look elsewhere. If there’s ice in the mold the most likely cause is the heater or ejector. If there's water it could be several things from the freezer temperature to the heater switch.
It's easier to figure out the problem if you have a simplified idea of how the ice making process works. An electromechanical timer controls the sequence of events for the entire process and acitivates valves and switches at the proper stage of the process. An ice mold receives water through an inlet valve. The mold is usually cooled just by the freezer air and relies on it's mass to retain the cold. Once the water has been in the mold for the correct time the cubes are given a brief shot of heat from a heating element in the mold. This loosens things up so a mechanical ejector can push the cubes from the mold. More water is added and the process continues.
please chek this link,for further help..
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Thanks for contacting Fixya.com
Oct 12, 2009 | Refrigerators
The ice maker on amana bottom freezer is not making ice?
Hi
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag MSD2754GR - Ice Maker quit working.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker stopped making ice,
Ice makers are pretty generic. Let's start with the water supply. You are positively getting water to the water valve in the back of the refrigerator? You can check this by disconnecting the copper or vinyl line on the water valve located at the back if the machine. If , you are getting water through this line, then, reach into the icemaker mold to see , if, there is ice or water in the mold. If, there is no water or ice, you have a defective water valve. Checking the water valve is easy, but, not for the faint of heart. Disconnect the leads to the water valve and apply 120 Volts to the water valve, if, the water valve doesn't activate the valve is shot. Sometimes a leaky water valve will cause the fill tube for the ice maker to freeze shut. You can check this by manually, with a flashlight by looking into the tube that supplies the water to the icemaker, if, it is frozen solid, the water valve is in need of replacement. If the aforementioned things are not the problem, get a new ice maker.
Jun 15, 2009 | Refrigerators
Kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Jan 02, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice maker makes very little ice
my under the counter ice machine makes very little ice. we just paid $600 to have a repairman put a new motor in it (although I don't think that was ever the problem) because it would always run, it was just not making any volume of ice. now it's been fixed and the repairman brought it back under th counter yesterday and it's STILL not making more than maybe 1 cup of ice in over 24 hours. I can hear the water running when Iopen it, but just don't get the bin full of ice like it used to get. HELP!!
Oct 16, 2007 | Hotpoint HSS25GFP Side by Side...
ULINE U Line 3000 Series 3018CLRS41 20" Built-in Undercounter Ice Maker with 30 lbs. Ice Storage, 60 lbs. Daily Ice Production, Frost Free, Clean Indicator Alert and Drain Required: Stainless Steel, Left Hinge with Pump Logo
340 people viewed this question
Top ULINE Kitchen Appliances - Others Experts
Lawrence Oravetz
ray gallant
Tom Chichester
Are you an ULINE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
