Woods Chest Freezer C1501W3 Logo
Angella Latte Posted on Jul 16, 2014
Is the light on my deep freezer supposed to flash and then go out for a period of time?
The blue temperature light and the green light is flashing on my danby deep freezer. Why is this?
One of these is a power light. It typically remains on while the freezer is in use. No light means either a blown bulb or no power. The other is associated with the thermostat. But it does NOT indicate that freezer temperature is appropriate. Flickering appears to indicate the bulbs are simply failing. The bulbs are neon, I think, and are not cheap. Some might try replacing such with LEDs. I have seen comment that the bulbs are not long lasting. www.manualslib.com has numerous danby freezer manuals but I do not know your model. Have a look.
What temperature should the freezer be set at?
Deep freezers are typically supposed to be at 0 Degrees (F) or slightly below, which allows food to be kept frozen for long periods of time.
Long running periods with Engel B 12v fridge
the owners manual will tell you but yes most do
Am I supposed to turn off the quick freeze once the deep freezer is cold?
http://www.mcappliance.com/document/MCCF5WBX.pdf
i read the entire manual and even type in the words "quick freeze" in pdf. find space and it is not in there.
heres the link read it for yourself
it only mentions green light and red light.
The “POWER” light (Green) indicates that the freezer is properly connected to the electrical power.
The “RUN” light (Red) will not illuminate when the unit is operating below freezing.
The “RUN” light will illuminate when the temperature inside the unit increases above freezing. Please
be advised that the “RUN” light may come on for a period of time when the lid is opened, when new
items are stored inside the unit or when the lid is forced open by irregular contents.
Do not call for service unless the “RUN” light has remained on for 6 hours or more. If this light stays
on continuously for a period of 6 hours, please contact our Customer Service Dept. to consult with a
representative at 888 775-0202 or visit our website to request warranty service at www.magicchefewave.
com.
1helpful
Kelvinator Single Door Hardening Cabinet Flash Freezer fan
If the fan motor shaft is smooth with 1 flat spot the hub on the blade probably has a hex set screw that can be tightned with an allen wrench. If the fan motor shaft is threaded there should be a nut holding the blade on. Also yur motor bearings could be going bad causing vibration which damages the fan blade.
3helpful
Kenmore Deep Freeze
sounds like just the bulb is going bad . the neon bulb you have goes bad that way ,it flashes and blinks sometimes for years before it goes out all the way . it will not hurt anything
Freezer switces off sporadically after periods of 20 to 10 days.
If this is a frost free refrigerator have the defrost timing unit checked out. It may well be sticking in the defrost position.
Nov 25, 2008 • Freezers
2answers
Problem with hussmann chest freezer
If the freezer is not located in an area where grease vapors are present the unit can be cleaned off using a vacuum cleaner. Then use a flash light to look through the coils. If you see dust embedded deep inside use a small air compressor to blow out the dust. Dirty condenser coils raise the pressures and temperatures in the system. Cleaning the coils and scheduling them to be clean at quarterly intervals should keep it functioning for a long time. Operating with a restricted condenser takes its tole on the compressor life span.
8helpful
2answers
Sears Kenmore Deep Freezer settings
i tilt my chest kenmore deep freezer to remove water when cleaning it by the time it was connected it didnt work
Top Woods Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Woods Freezer Expert? Answer questions, earn points and help others
