Im new at this so im not sure if im doing this right,im not that good with computers,and i really didnt mean to spend no 99.00 dollars.
SOURCE: My 30G 5th Generation pod is totally dead and will not charge even with a new battery
I have tried everything including replacing the battery but the ipod 5th generation will not recharge. When a new battery is put in the iPod will continue to work until it runs out of battery.
SOURCE: my ipod is on but blank screen
just leave it and let it run flat then charge it again then its good as new
SOURCE: My Computer and iTunes does not recognize my iPod
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
SOURCE: 120 GB iPod has red X and wont go into disk mode
I would back up all the media from the ipod as soon as possible.
SOURCE: Ipod wont turn on. ive tried everything! none worked! HELP!
You will want to attempt to force the iPod into disc mode before restoring. This should solve your issue.
Toggle the Hold switch on and off.
(Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Please let me know if this did not resolve your issue. :)
