Eureka Pet Pal Bagless Vacuum Logo
A
Anonymous Posted on Jul 16, 2014
What size belt does a eureka pet pal use - Eureka Pet Pal Bagless Vacuum
Think Crucial
Level 3:
Master:
  • Eureka Master 894 Answers
  • Posted on Jul 17, 2014
Think Crucial
Eureka Master
Level 3:
Master:
Answers
894
Questions
0
Helped
710801
Points
8395
Hi, it's Jeremy from Crucial Vacuum.
The Eureka Pet Pal requires Eureka U belts.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=eureka+u+belts
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
1 Related Answer
Anonymous
  • Posted on Dec 10, 2011
SOURCE: How do I change the belt on Eureka Pet Pal
Unlike most vacuums, this one the screws are on the top of your base. There are two screws one on each side. When looking at the front of the vacuum right side screw is located above the s in 12amps and on the left side screw is located above the p in pet. Now keep in mind it's not directly above the letters look about 2 inches up. Unscrew them, take cover off. Once you have done that pull up on the brush rod. Maybe tough if ur vacuum has a lot of built up dirt. Next put belt on metal prong then put on brush rod. Place rod back in its spot, gonna need little bit of muscle. Then put top back on and replace screws. Plug in flip bottom just to make sure brush is spinning. If u have followed steps this should work. I hope this helped took me forever to find the screws because I have always had vacuum with them on the bottom and internet was no help to me. Good luck
Eureka vacuum belt model number 3271
you can check this link. I guess this should be helpful. If not, check for the related products underneath.
Can you tell me how to change the belt on my eureka AS3001A vacuum. It is belt 75914 for the pet power paw attachment. Please help,
Swivel the collar at the smaller end where it attaches to the vacuum which will allow the clear plastic cover to come off which will allow you to pull out the brushroll and belt to replace it. Reverse to reassemble.
How do I stop Eureka Pet Express from making loud noise?
does it make the noise with belt disconected if not its the brush . it could be installed wrong check it.
Theres smoke coming from the motor of the eureka pet pal bagless vacuum cleaner.. i dont know what to do
Some vacs have two belts. Is urs also self powered? If so, has a separate belt. With model # can give better info.
1helpful
Need to change belt
click the link below for the manual it will give you step by step instructions how to change the belt,
http://www.eureka.com/FileLibrary/7f8e42f94c4146dea58673f01e6464a7/en_80509_OwnersManual.pdf
27helpful
2answers
Top Eureka Vacuums Experts
Mike Cairns
Mike Cairns
Jo Ri
Level 1 Expert
Alexander
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
