Question about Microwave Ovens
I have a whirlpool gold electric microwave/lower oven combination model gmc305. The microwave keeps blog wing a fuse, is there a repair for this problem?
Posted by Bill Bersbach on
Chuck
    Sergeant:
  • 228 Answers
You must be observant and determine when the fuse is blowing. Clues are needed to solve problems.
Posted on Jul 19, 2014
5 Related Answers
Anonymous
SOURCE: Whirlpool microwave/oven model RM286PXV3
I have a 13yr old above-range oven which quit when my wife cooked food in an aluminized foil wrapper (a small fire ensued!). This oven has 3 thermal protection units, on the magnetron, the chassis and on top of the food cavity. This last one had failed open, and since it's in series with the magnetron thermal protection unit and the main relay, nothing would work. MAT electronics sell the units for less than $4, but my problem now is to pick one with the appropriate temperature cut-off. They range from 200 to 300F.
Posted on Nov 18, 2006
najah
ABDUL MAJEED
  • 180 Answers
SOURCE: Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
Posted on May 24, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Microwave lamp burn't out
You can find owner's manuals (which would cover any user-replaceable lights if present), installation instructions, and parts list, which have helpful exploded view diagrams here.
You can order parts here.
Posted on Jun 30, 2009
Anonymous
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
Posted on Nov 09, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: How do I replace the light on a Whirlpool Gold
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Sep 08, 2010
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
I have a whirlpool combination microwave with oven. How do I change the bulb in the microwave?
Whirlpool Microwave Bulb Replacment - YouTube
? 4:35
https://www.youtube.com/watch?v=RQM302PShKw
Oct 29, 2011 - Uploaded by Dan Jiles
I show how to access the bulb on a Whirlpool Microwave that shines on your cook top, as well as how to access and replacethe bulb that is for the microwave ... ... How to disassemblemicrowave oven. Find info: fuse, bulb, fan ..
Nov 07, 2015 | Whirlpool Microwave Ovens
I have a whirlpool microwave model WMH31017AS1 it turns on but heat up is there anything i can do
All microwaves have a door open switch that keeps the magnetron from producing microwaves; this could be your problem. Most microwaves have a fuse hidden in the wiring that blows on overload like a lot of food spatter inside. They also have thermal overloads which may or may not self reset. If it died with a big flash you may be out of luck, if not you may be able to locate the fuse or thermal limit and replace it. Another sneaky part is a one time combination temperature and current overload called a thermal fuse:
51cl8ujqerl._sl1100_.jpgThese thermal fuses are marked in amperage and degrees Celsius and Amazon carries them.
Self resetting thermal overloads look like this Amazon # B00DM8JGQQ which is a Whirlpool part:
I didn't find a wiring diagram on line for your model, but you may be able to find one; whirlpool generally is pretty good with documentation. Most microwave manufacturers keep consumers as far from doing their own repairs due to the possible dangers involved.
Appliance Parts Store has a pretty good selection of replacement parts
WMH31017AS Parts
Jan 30, 2015 | Whirlpool Microwave Ovens
Whirlpool Electric combination Microwave and Oven -- when I try to turn on the microwave the words "door" comes on screen and unit does not start. The door does latch but still does not start....
I could have been more specific with a model number, but if this general answer doesn't do the trick, feel free to contact me with your full model and specific symptoms here.
It's usually a bad door switch or door switch mount. My helpful text file on door switches is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's one of those overdesigned Whirlpools, it can be one of many components. See the example photo at the bottom of this reply.
Oct 05, 2011 | Whirlpool RMC275PD Microwave Oven
How do I replace the light on a Whirlpool Gold Microwave GMC275 or GMC305? Thanks for your help!
Sep 08, 2010 | Whirlpool GH7145XF Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
How do I replace the fuse or reset the circuit on a Whirlpool Microwave Hood Combination Model MH7155xm.
remove the outer cover and its in a fuse holder on the right side of unit get the right amperage
Oct 01, 2009 | Whirlpool MH7155XM Microwave Oven
Microwave Ovens Logo
90 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
