See below. Are you aware of this recall? Do you know if the bike has been checked?
HARLEY-DAVIDSON MOTOR COMPANY
Make / Models : Model/Build Years:
HARLEY-DAVIDSON - FXD - 2009 HARLEY-DAVIDSON - FXDB - 2009 HARLEY-DAVIDSON - FXDC - 2009 HARLEY-DAVIDSON - FXDF - 2009 HARLEY-DAVIDSON - FXDL - 2009
NHTSA CAMPAIGN ID Number:
Recall Date:
DEC 10, 2008
Component:
STRUCTURE - MOTORCYCLE KICKSTAND - CENTER STAND
Potential Number Of Units Affected:
Summary:
HARLEY-DAVIDSON IS RECALLING 3,285 MY 2009 FXD, FXDF, FXDC, FXDL, AND FXDB MOTORCYCLES. THE JIFFY STAND SPRING ANCHOR MAY HAVE BEEN BUILT WITH A DEFECTIVE WELD THAT MAY ALLOW THE JIFFY STAND ASSEMBLY TO NOT RETRACT AS INTENDED.
Consequence:
HIS CONDITION COULD LEAD TO A CRASH WHICH COULD CAUSE INJURY OR DEATH TO THE RIDER.
Remedy:
DEALERS WILL REMOVE THE ORIGINAL JIFFY STAND SPRING ANCHOR AND REPLACE IT WITH A NEW SPRING ANCHOR FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR ABOUT DECEMBER 22, 2008. OWNERS MAY CONTACT HARLEY-DAVIDSON AT 1-414-342-4680.
Notes:
HARLEY-DAVIDSON RECALL NO. 0137. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
SOURCE: 93 Dyna low rider fork oil.
your local hd shop should be able to answer this for you as its a mesured amount and to much or too little will make the bike not handle right
SOURCE: Add transmission fluid to 2001 Harley dyna low rider
the tranny plug is behind the oil spout its usually a big allen head bolt. You should use a quality oil like AMSOIL 20W50 motorcycle oil or AMSOIL gear oil. I have the 20W50 in mine and really like the benifit of not having a pultrolium product in my bike. You can get the AMSOIL online a http://hbsynlube.com/sales. You'll beglad you changed it.
SOURCE: how do you remove battery from dyna low rider
I have an early model and I think they're still the same in that area. There are two bolts on the right side of the battery support. Loosen these two bolts and the battery will drop down a bit allowing you to remove the battery top cover and front cover.
SOURCE: What is the fork oil capacity for a 2004 Dyna Low
If I am not mistaken. You will need ten ounces per side ounce you have completely drained them
SOURCE: how to change primary chain tension on 2007 Harley
Sorry, not up on new hogs but I think you remove plate off outer primary,it's got the foot peg mounted on it.Look through hole and you'll see the bolt that holds the chain support unit.Carefully loosen bolt and pry up or down,tighten or loosen, tension.You don't have belt right? some newer ones do.If you want hi-tech and yours doesn't have one already remove the outer primary and replace the "skidplate" adjuster with a roller type.Makes things quiet.There is room in the hole to check that you don't get chain too tight.
