Fellowes Venus 125 Laminator 5215901 Logo
A
Anonymous Posted on Jul 16, 2014
How do i get my Fellowes Venus 125 Laminator 5215901 to stop bleeping and heat up ?
When i turn on the laminator it goes though a cycle like a bit test then bleeps and the logo flashes (constantley) and will not turn on i have been unable to stop the bleeping and it will not heat up?
Isaac mondragon
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 20, 2016
Isaac mondragon
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3154
Points
LEONARD MCCARTHY Your answer does not help!!!!! I have a jupiter 125 that wont stop beeping i Open it removed all the screws to uncover the motor drive and there is a sensor that pop up and down this is what releases the top cover when it making a loud noise ! it was stuck by the spring metal a the sheet of metal! there also a ***** on the bottom of laminator that say "remove this *****" this hold the spring sensor and stop if you tighten this *****. it stop the noise when i connected to trouble shoot but when i put back together i started making the noise again! my guess is that has to do with that sensor spring is getting stuck or faulty!
LEONARD MCCARTHY
Level 2:
  • Expert 189 Answers
  • Posted on Jul 19, 2014
LEONARD MCCARTHY
Expert
Level 2:
Answers
189
Questions
Helped
54982
Points
307
Unfortunately, this message was posted in the section for paper shredders. If you still need an answer you will need to repost it.
2answers
How can I open a Fellowes Venus 2 125 Laminator as I have a small pouch stuck in it and it won't come out
I had this happen where I worked and I elected to fix it. You have to remove the screws in the base, and IIRC the ends. Then I used a knife to cut the laminate pouch and pull out the pieces with pliers. If you can turn it on without damaging the machine or zapping yourself, the heat will help. My boss ordered a replacement which turned up a few days later :>D
https://www.google.com/search?q=Fellowes+Venus+2+125+laminator+jammed
Why won't my laminator turn on?
There is a heating unit inside of a hot laminator. Sometimes when you use this machine for too long it can damage some of the internal components because most of those things are full of plastic. You may want to see if Fellows can take it back under warranty. If they can't you are going to have to get a new one.
1helpful
Need a gear box for a Fellowes Voyager 125 laminator
Hi, I have a one that the PCB board is gone, the motor and shredder is perfect. You can buy the top with the motor frame from me if you like. It works sometime in reverse, but the safety light does not come on. Alternative sell me your PCB card
Fellowes laminator
Plz try the "Jam free" lever located on the top LEFT of the laminator. You ca try to feed another film in....hoping it will force the pouch out. Otherwise, you will have to take the cover off and unroll the pouch from the inside rollers. Good luck!
Beeping and not turning on
This is the second laminator of the same model that is beeping and not turning on. What do we need to do to get this machine operational?
Laminator Jammed! I have a fellowes saturn 125 laminator. there is an item stuck inside that is not sticking out on either side, so cannot be pulled out, even when the reslease lever is pushed. can i...
once you take it apart it voids all warrants if you have any.
if you do not have any warrant parts than that the only way you are going to fix the issue.
here is what some one gave me some tips on disassembly of equipment. draw a picture of the device, mark the area of screw layouts, after separating the 2 parts draw diagram of each part, make foot notes on what you did, screw locations, parts removed, parts cleaned, PUT EVERYTHING IN A LINE IN THE ORDER OF REMOVAL PARTS, than work backwards and put everything back the way you took it apart, you should not have any extra parts and it should work fine. than if it every happens again you have your notes and information on hand to help you. you could try this site.
www.ask.com/
www.manualonline.com/
/mfg.name/make/model#/
www.mfg.name.wow/manuals/service/
www.manuals.wow.com/make/model#/service/repair/
www.disassembly.wow.com/mfg.name/make/model/instructions/
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
Sean Wright
Sean Wright
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
