Question about Cell Phones
How to send a item via bluetooth from telefunken instructions
How to send a item via Bluetooth from the phone
Posted by levine on
Akram Al-samirraee
    New Friend:
  • 16 Answers
If your phone type(Nokia,Samsung, LG,or any smart phone contain Android System):
1st select file who need to sent it via Bluetooth.
2nd request from your friend to make his Bluetooth in his phone (ON).
3rd send the file.
If your type phone is (I-Phone) you can just send to same phone type:
1st select the file who need to send it and see this picture.
how to send a item via bluetooth from telefunken i - c1535756-d5e5-4b9b-aa3f-c7f1115aeb48.png
must your friend press on the bottom in red cycle and then
2nd show this picture.
must your friend press the bottom in red cychow to send a item via bluetooth from telefunken i - 6ea915c2-39dc-4e3a-9e9d-40414bf35c33.pngc="/uploads/images/6ea915c2-39dc-4e3a-how to send a item via bluetooth from telefunken i - 78e875e3-9721-43e4-ba8a-bcf8f2b971f1.pngc-4e3a-9e9d-40414bf35c33.png" class="hhow to send a item via bluetooth from telefunken i - 09dd3f27-8631-4a8d-980d-b8588f644d9e.pnge3-9721-43e4-ba8a-bcf8f2b971f1.png" alt="78e875e3-9721-43e4-ba8a-bcf8f2b971f1.png" class="h_mi" /> 09dd3f27-8631-4a8d-980d-b8588f644d9e.png
then your AirDrop available like this picture below:
then you friend's name appears instead of the AirDrop and he must apply you to received file
Posted on Jul 16, 2014
How to send more than one file in SGH e490 via Bluetooth cause i don't have an option to select more than one file when i will send via Bluetooth ?
first go to file you want to send then click on options send via bluetooth, then it will show whole files in the folder mark multiple items and send .....
Sep 27, 2011 | Samsung SGH-E490 Tri-band Phone
I can't activate the bluetooth on a samsunh sgh j700
You can activate the bluetooth for this phone by following the instructions below as they come to you. If you are not clear on any part, please contact me.
1. Go to the main menu of your phone.
2. Scroll through to the application menu,
3. Open it and select bluetooth. From here, you can activate the bluetooth feature on your phone.
You have to follow the above instruction if you want to receive an item from another phone via bluetooth. Sometimes, you might be asked to pair your phone using a code, this is normal depending on the phones involved.
Also, if you want to send an item from you phone to another phone, all you need to do is to select the item and press the options button and select "send via" and the choose bluetooth from the menu.
Hope this was helpful? Please remember to check back with me if you are not sure of anything and I would explain better, Thank you for using FixYa.
May 19, 2011 | Cell Phones
Unable perform blue tooth operation
you should be having bluetooth in the computer. open the bluetooth of the mobile and put the option '' visible to everyone'' ON. then open the bluetooth in your computer and search for the devices. when it read your mobile, connect it (Double click it). it may ask for a passkey, write any number and then when you press ok, it will ask for passkey on your mobile. write the same number there and it will pair the two devices. then select any item from your mobile and select '' send via bluetooth'' it will search for the bluetooth items arround and definitely will find your computer. select it and it will send the item from mobile to the computer. While sending something from the computer to mobile, ensure that mobile bluetooth is on and ''visible to everyone'' option is on. Then select the file from computer, right click on it and select ''send to'' option. in that there should be an option ''bluetooth'' click it and it will search for the devices having bluetooth and will find your mobile. select your mobile and it will start sending the file
Sep 07, 2010 | Nokia N72 Cellular Phone
How to connect computer through blue tooth
Sep 07, 2010 | Motorola Mobility L6 Cellular Phone
How to connect samsung tocco mobile to another samsung tocco mobile using bluetooth?
Turn on the Bluetooth wireless feature.
To turn on the Bluetooth follow the below steps,
1. In Menu mode, select Applications > Bluetooth.
2.. Select the circle in the center to turn on the Bluetooth wireless feature.
3.. To allow other devices to locate your phone, select Settings > On under My phone’s visibility > Save.
To connect other device to your mobile
1. In Menu mode, select Applications Bluetooth Search.
2. Select and drag a device icon into the centre.
3. Enter a PIN for the Bluetooth wireless feature or the other device’s Bluetooth PIN, if it has one, and select OK.
When the owner of the other device enters the same PIN or accepts the connection, pairing is complete.
After connecting you can start sending the files from one mobile to another mobile.
To send files follow the below steps.
1. Select the file or item from one of your phone’s applications that you want to send.
2. Select Send via or Send URL via Bluetooth, or select More Send via Bluetooth
Thank You
Aug 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Bluetooth from lg 290cm
Straight Talk phones can only send and recieve items via bluetooth to other Straight Talk customers
Nov 15, 2009 | Cell Phones
Bluetooth
its simple to send data via bluetooth ........first enable bluetooth .....select the item you need to send ........in send option select bluetooth .....thats enough your data can be sent .....
Feb 02, 2009 | Motorola Mobility PEBL U6 Cellular Phone
Bluetooth
What are you trying to send? Picture, video, ringtone, app?
For a ringtone, go to the Media Finder, select ringtones, then "All Ringtones" and scroll to the one you want to send. Hit "options" and scroll to the option "Send"
Select "Send" and one option should be "send Via Bluetooth"
The process should be similar for other sendable items.
Feb 02, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Bluetooth
restore ur handset.and try via diff handset for confirmation purposes.
Oct 23, 2007 | Nokia N95 Cellular Phone
Sending photos via bluetooth
if photo are very important then you simply copy those photos in
phone memory,and then you able to send those photose via blue-tooth,if not purchase a card reader to read the memory card
if you have data cable then nothing to say connect it to usb port run the pc-suit.
Oct 15, 2007 | Sony Ericsson K750i Cellular Phone
Cell Phones Logo
66 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
