1991 Mercury Capri Logo
A
Anonymous Posted on Jul 16, 2014
REPLACE A POSITIVE BATTERY CABLE
SOMEONE BROKE INTO MY CAR AND CUT OFF MY BATTERY CABLES. I BOUGHT NEW ONES BUT DONT KNOW WHERE TO HOOK THE BACK TOGETHER.
Ed Boothe
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 16, 2014
Ed Boothe
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
149
Points
The positive cable will connect to your starter and alternator. The negative connects to an engine ground. For more info check out - www.techcapri.com
Lawrence Oravetz
Level 3:
  • Mercury Master 10,558 Answers
Lawrence Oravetz
Mercury Master
Level 3:
Answers
10558
Questions
Helped
2697367
Points
29284
The red one goes to the positive. the other one goes to Negative on the battery.
3 Related Answers
jmeyer847
Jeremiah Meyer
  • 204 Answers
  • Posted on Jan 06, 2009
SOURCE: battery cables
4 gauge wires will be ok. Thanks for using FixYa!
Sincerely,
JC
Anonymous
  • 1403 Answers
  • Posted on Dec 31, 2010
SOURCE: there is a wire attached
the car started and run before? if so, bypass the wire with a wire connection kit from autozone or advance auto,it may be a metal fuse link for an added stereo,or another application. it may even be a fuseable link. if so take it off, then go to parts place and do not be afraid to ask questions!you may have to buy an application to car to make it run safely.so what!i would sleep better knowing i did not give you wrong advice.disconnect the application, take it to autozone, advance auto,nappa. and find out what the application is. you cannot go wrong by doing that, don't be afraid to ask questions! if i could see it, i would be able to tell you what to do and how. but i can't thank you for choosing fixya.com
Willie Keisser
  • 457 Answers
  • Posted on Aug 07, 2011
SOURCE: What is the best way cut and reattach a new
go fron starter to battery make no splises at all as this will drop your current to start and will only have about 10v when reaches the starter any may work but sluggish.thair are 3 because you need one for started, one for fuse panel and one of comp.
How to change negative battery cable
Put on safety glasses and gloves
Ensure the car is turned off
Locate the battery
Determine which is the positive and which is the negative terminal
Remove boxes or tape covering the end of the cable
Disconnect the negative cable
Disconnect the positive cable
Remove the battery
Remove the negative cable, then the positive
Compare the new and old cables
Prepare the new cables for installation
Attach the positive cable to the starter
Attach the negative cable to the body or block
Place the battery back in the car
Connect the positive battery cable to the battery
Connect the negative cable
Start the car
My car battery went dead, bought a new one, every time I hook up positive cable, car alarm goes off........
remove alarm reinstall after fitting. at least cut power supply and back up supply fit battery repair reinstall alarm.
Convert battery cables from top post to side mount replacement ends?
If all you are doing is changing to a side post battery, just connect all the positive cables from the old pos post to the new pos holder and all the neg ones to the new neg holder. If you've already cut them all off and not sure where each wire goes, all the reds are positive, all the blacks are neg. To make sure use your continuity meter to test. Connect one meter lead to any good clean metal part on the car and test between each black wire in turn, the neg ones will show a circuit, the pos ones will not.
How can i know if my starter relay is bad on a dodge stratus 2001
IF STARTER RELAY BAD THE STARTER WONT MAKE NO NOISE AT ALL HEADLIGHTS WONT DIM.IF YOU CLICKING NOISE BATTERY VOLTAGE TOO LOW. MAKE SURE BATTERY VOLTS ARE 12.6 VOLTS AND USE TEST LIGHT TO SEE IF STARTER GETTING POWER.COULD HAVE BLOWED IGNITION FUSE OR FAULTY IGNITION SWITCH. TO CHECK STARTER SOLENOID FIRST TURN OFF RADIO THEN REMOVE NEGATIVE BATTERY CABLE AND POSITIVE BATTERY CABLE.THEN REMOVE STARTER BUY A REMOTE SWITCH.YOU NEED BATTERY JUMPER CABLES HOOK BATTERY JUMPER CABLES TO BATTERY PUT POSITIVE CABLE ON POSITIVE BATTERY POST THEN PUT NEGATIVE BATTERY CABLE ON NEGATIVE POST. HOOK BATTERY CABLES TO STARTER USE NEGATIVE CABLE GROUND STARTER BODY AND PUT POSITIVE BATTERY CABLE ON THE LARGE POSITIVE POST ON STARTER SOLENOID. NOW TAKE REMOTE SWITCH HOOK RED WIRE TO STARTER SOLENOID POSITIVE POST THEN HOOK BLACK WIRE TO REMOTE SWITCH TO STARTER SOLENOID SWITCH TERMINAL WITH LETTER S THEN PRESS REMOTE IF STARTER SPINS STRONG WITH A GOOD KICK STARTER GOOD.YOUR PROBLEM COULD BE CORRODED WORN BATTERY CABLES. WEAK BATTERY FAULTY IGNITION SWITCH. IF STARTER DONT WORK WHEN YOU PRESS THE REMOTE SWITCH STARTER SOLNOID BAD OR STARTER ITSELF BAD.IF ALL IS GOOD. CODE SCAN CAR FOR THEFT SECURITY FAULT CODE.
My negative cable that goes from the starter to the battery broke,how do I replace this cable? Any help would be appreciated
they sell generic cables at parts stores, however for that application i like to use a cable which is made specially for the car, so a dealer is the place to get it. otherwise you have to cut the heavy cable and make a crimped mechanical connection between the connector lug and the cable which inevitably leads to corrosion eating the connection out from the inside. from time to time you see these sold on eBay.
generally the negative cable leaves the battery and bolts to vehicle ground, not the starter. the positive cable leaves the battery and bolts to the starter. make absolutely sure you have the right cable in mind before you buy. if it is the positive cable, disconnect the negative cable before you begin to hook up the positive cable to avoid sparks and serendipitous welding. just unbolts at each end, may be some guides to follow in order keep the cable from moving around.
after the swap do not be surprised to find your anti-theft radio no longer works, you will need to contact a dealer with proof of ownership to get a code.
Have a delcotron alternator ,what to know where no.1 terminal and no.2terminal wire goes it is on my 1946 cj2a jeep my amp hand does not show a charge had alternator checked out and is ok
  • Use a wrench to remove the negative and positive battery cables: They are clearly labeled "+" and "-." Always remove the negative cable first, as this isolates the power to the metal parts of your car. Tuck the cables away from the battery as you don't want them to accidentally touch a battery terminal when you're wiring your alternator.
  • 3
    Locate the alternator terminals. There are two: one marked "live," "pos" or "+" and the other marked "neg," "field" or "-."
  • 4
    Locate the two cables. The positive (red) cable goes to your battery via a wire loom or harness. The negative (black) cable attaches to a metal part of your car.
  • 5
    Check how the cables attach to the alternator terminals. Some connect using eyelets that hook over the terminal and tighten with a bolt; others connect by inserting the wire under the terminal and tightening a bolt.
  • 6
    Loosen the two bolts using a suitable-sized wrench or, if the cables connect using eyelets, remove the bolts.
  • 7
    Insert the exposed end of the negative (black) cable under the loosened bolt on the negative terminal of the alternator, then tighten the bolt. If the cable has an eyelet, hook it over the terminal and screw the bolt back in place and tighten using a wrench.
  • 8
    Insert the exposed end of the positive (red) cable under the loosened bolt on the positive terminal of the alternator, then tighten the bolt. If the cable has an eyelet, hook it over the terminal and screw the bolt back in place and tighten using a wrench.
  • 9
    Replace the positive battery cable on the positive battery terminal using a wrench. Replace the negative battery cable on the negative battery terminal.
  • 1helpful
    96 Olds Aurora wont start nothing happens when i turn the key,battery is good.
    CHECK THE INSTRUMENT CLUSTER FOR POWER TO GAUGES TO SEE IF THEY WORK WHILE IGNITION IS IN THE ON POSITION.IF NO CHECK THE 40 AMP IGNITION FUSE.IF FUSE GOOD IGNITION SWITCH IS BAD OR HAS A LOOSE OR BROKEN WIRE.IF FUSE GOOD ALL GAUGES IS WORKING.I BE LOOKING AT STARTER AND STARTER SOLENOID.REMOVE THEM HAVE AUTO ZONE TEST STARTER.OR YOU CAN GET A REMOTE STARTER SWITCH AND SET OF BATTERY CABLES.HOOK BATTERY CABLES TO A BATTERY.WITH STARTER OUT OF CAR TAKE BATTERY CABLES HOOK NEGATIVE BATTERY TO STARTER BODY FOR GOOD GROUND.TAKE POSITIVE BATTERY CABLE HOOK TO STARTER POSITIVE TERMINAL WHERE POSITIVE BATTERY CABLE GOES.THEN HOOK THE REMOTE SWITCH RED WIRE TO STARTER POSITIVE TERMINAL AND THE OTHER REMOTE SWITCH WIRE TO THE S OR SWITCH TERMINAL ON STARTER SOLENOID.PRESS THE REMOTE SWITCH IS STARTER RUNS GOOD WITH NO FUNNY NOISES ITS GOOD IF STARTER DONT RUN THE STARTER SOLENOID OR STARTER IS BAD. THE PROBLEMS IN YOUR CAR COULD BE A BAD KEY TRY ANOTHER KEY YOUR CAR HAS THE THEFT DETERRENT MODULE SYSTEM BEST TO HAVE CAR SCAN TO CHECK THE THEFT SECURITY MODULE AND THE TRANSMISSION NEUTRAL SAFETY SWITCH IF ITS BAD STARTER WONT WORK.ALSO CHECK THE THEFT DETERRENT MODULE RELAY. BEFORE REMOVING BATTERY CABLES TURN OFF RADIO SO YOU WONT LOSE YOUR RADIO PLAYING CODE.
    2answers
    Replace positive battery cable 97 montero
    A lot of cars have two cables on the positive post.
    Do you need to replace the cables or is the battery post clamp broken. You can buy a replacement post clamp if you have the type of cables that are bolted to the clamp.
    If you need the cable, a oem replacement from your dealer parts counter will match. You can get after market replacements, just look for one that matches your original as close as possible. The parts counter guy should be able to help.
    1995 olds 88 positive battery cable stuck together
    Crazyshaws:
    Normally the bolt that tightens the clamp that fits down over the positive post of the battery can be removed from the cable. What happens on older cars is the bolt get all fouled up and corroded. This happened recently to me on my 94 F150. What I did was to cut the bolt in the middle with a hacksaw, then went to the auto parts store and bought a new bolt & nut for the cable and installed it. They even have packages of 2 nuts and bolts right near where the batteries are sold.
    Hope this helps Good luck Loringh PS Please leave a rating if appropriate Thks
    Top Mercury Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Thomas Perkins
    Thomas Perkins
    Are you a Mercury Expert? Answer questions, earn points and help others
