NEC "AccuSync LCD22WMGX - LCD display - TFT - 22"" - widescreen - " Logo
Alice Ar'Grim Posted on Jan 26, 2018
How to unlock monitor buttons?
The monitor buttons are locked out and do not allow for control of the monitor. this includes source selection and even the power button. to power the monitor down I have to unplug it from the power source, and the input is stuck preventing me from changing it to the correct input for my device.
tip
Dell monitor Lock and Unlock instruction
'OSD Lock': Controls user access to adjustments. When 'Yes' (+) is selected, no user adjustments are allowed. All buttons are locked except the menu button.
All buttons can be locked or unlocked when the 'Menu' button is pushed and held for over 15 seconds.
May not be applied to ALL Dell.
http://support.dell.com/support/edocs/monitors/E153fpb/En/controls.htm
http://support.dell.com/support/edocs/monitors/E173FP/En/controls.htm
http://support.dell.com/support/edocs/monitors/SE198WFP/en/setup.htm#Using%20the%20OSD
http://support.dell.com/support/edocs/monitors/3008WFP/en/ug/operate.htm
on Apr 14, 2010 • Computers & Internet
My 42 FD 9954 Philips flat TV monitor has a channel lock I can't get it unlocked what do I do
How to lock or unlock channelsTo lock or unlock channels:
  1. Press the Menu button on your remote control.
  2. Select Settings.
  3. Highlight System and press OK/Select.
  4. Select Parental/Purchase.
  5. Enter your Parental Controls PIN.
  6. Select Parental Preferences.
To lock or unlock all channels:
Select Lock All or Unlock All and press OK.
To lock or unlock specific channels:
Select Block by Channel > Add or Remove Channels.
From there you can select to Lock All, Unlock All, or
select specific channel(s) that you'd like to lock or unlock.
2answers
My menu control is locked and i want to know how to unlock this dell P2210t
pressing the Menu button takes you directly to the OSD settings menu. You should then select the Unlock option to unlock and allow user access to all applicable settings
7helpful
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
3answers
Cn-ou4931-46633-52L-OHGU - monitor keeps showing
Here you go!
From Dell website:
All buttons can be locked or unlocked when the 'Menu' button is pushed and held for over 15 seconds. See more here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
1helpful
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
LCD Monitor will not switch input selections
NOTE: You can also lock or unlock the OSD by pushing and holding the Menu button for 15 seconds. In this mode All buttons will be locked including the "Menu" button. You can unlock by pushing and holding the Menu button for 15 seconds.
Reference:
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
14helpful
3answers
Monitor displays "Controls Locked"
This is a "feature" they include to prevent accidental changes to the screen setup. You should be able to unlock the OSD by pushing the Menu button and the right arrow button together for about three seconds. The message "controls unlocked" should appear. Let us know if you have any other questions and please don't forget to rate the posting.
Top NEC Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
