Washing Machines Logo
A
Anonymous Posted on Jul 15, 2014
Hot and warm water surges while filling
Model number 110.28622701. When it is filling warm or hot water it suddenly started to do this in spurts, not an even flow. It doesn't seem to do it with the cold.
5 Related Answers
Anonymous
  • 883 Answers
  • Posted on Jul 17, 2007
SOURCE: Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Anonymous
  • 447 Answers
  • Posted on Dec 02, 2007
SOURCE: kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Anonymous
  • 145 Answers
  • Posted on Apr 18, 2008
SOURCE: Hot water is filling up washer very slow
There is a screen in the valve where the hose hooks on. It could be getting plugged up. turn off the water and pull off the hose to see if it's full of particles. I can sometimes clean it out by putting a bucket under the water inlet and spaying a little water from the hose into the opening. If not you may need a new valve.
Anonymous
  • 311 Answers
  • Posted on Nov 30, 2008
SOURCE: Washer is using hot water on the cold/cold was
Unless your hoses are reversed the machine control is bad and needs to be replaced. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Anonymous
  • Posted on Dec 14, 2008
SOURCE: cold water filling
There are filter screens where the supply hoses connect to the washer. On some brands there is a screen where the hose connects to the water valve at the wall. The screen is probably full of sediment.
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
1helpful
When washer fills on warm water mode, it alternates between cold and hot water coming out in spurts. Is this normal, as it doesnt do it on rinse cycle.
yes its normal the reason it does not do it on rinse is that only cold water is used to rinse not /hot warm
please rank this advice if it helped
thank you
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
1helpful
Maytag washer causes water pipes to rattle when filling
Could be something called water hammer which is a pipe issue. You can install/have installed a water hammer arrestor which is a small pipe extension that stops that.
Hot water will not fill into the tank when starting cycle.
The ECU is at fault.
Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
You probaby have an inop hot water fill valve.
When filling my F&Paykel washer the water is not a constant flow, it is filling in 'spurts', ie stop/start/stop/start etc...... I have tried cold, hot & warm water, all combinations of temp are...
You most likely have a smart water temp sensor on your machine. It makes sure you have the proper water temp to dissolve your detergent. Even when set to cold, it will add some hot water. It sounds like your machine is working properly. If you feel you are haveing a problem check the water temperatures in your owners manual and then check them with a thermomater in the washer. If they are not correct you may have a bad temperature sensor. Good Luck and I hope this helped. [email protected]
Alexander
vince
