SOURCE: Canon iR6570 waste toner
look on the right rear of the machine, there should be a door with 2-4 screws. A big white plastic container should be there, remove dump toner and seal bag, replace. Make sure it is sitting properly, it uses a weight system.
SOURCE: sir ; i have a canon ir6570 machine,it was
this problem due to an over current has been detected in the toner feed motor,you must check the connector or replace the motor
the waste toner bottle is stuck int he hopper assembly
try removing the toner bottle and reseating it
if it doesn't work then you blew a fuse on the dc controller board
