Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Battery dead, can't find keys, is it possible to obtain another key? what info do you require if answer is yes.
Grady Turner
    Scholar:
    New Friend:
  • 101 Answers
A locksmith should be able to pick the lock and make a new key. Manufacturer might have replacement keys, but you'd need either the key code or safe serial number.
Posted on Jul 22, 2014
  • Grady Turner Jul 22, 2014
    A locksmith should be able to pick the lock and make a new key. Manufacturer might have replacement keys, but you'd need either the key code or safe serial number. On some safes batteries can b replaced without opening the safe. Pass codes are retained until reset.
1 Related Answer
mat_droid
mat_droid
SOURCE: I have a Micromark Electronic Safe 40043 - Keys lost in transit to China. Batteries dead. Safe Locked!!!! WHERE CAN I GET A KEY?
How do i lock it
Posted on Oct 19, 2012
My key is stuck in open position, cannot turn it or remove it. Any ideas.
didnt specify vehicle - generic answer - possible dead battery if key wont go to off position try boosting and key will turn to off to remove or under key on steering column is an access hole that you can get a small screw driver or paper clip push release and turn to off to remove key
May 05, 2018 | Cars & Trucks
Engine wont crank, no fuel pump running but has ignition. ETC light stays on longer than bulb check should.
no crank, is basic starter path failure
the lamps are useless here,
ill guess automatic trans.....
forget pump, just starter.
does it crank in neutral as instructed in the oper,guide?
yes/no
if yes, park switch
no, the jumper cable crank engine, does it crank now.?
yes, battery was dead, or lugs corroded green
no? then clean lugs, rpeat
no? the starter bad or key line bad
next
HOT WIRE THE STARTER At solenoid(keys in pocket)
no crank with good battery,starter is bad. (or possible cables)
yes, crank well now you know your starters good in 5min.work
this means the KEY line is dead.
id scan the pcm now or first,is better.
some cars have starter relay
what happens is the PRNDL switch in the trans
in P or N , energizes said relay allowing the key line 12v reach said starter small lug.
see?
only $10 voltmeter i see the cause fast.
easy .
the key in must be 11v or more. cranking.
if 0 or real low bad line, 8v the solenoid chatters.so....
ending my secrets now..
no tools? nor meter?
charge your battery?> have some one charge it and test it.?
jumper cable crank it(call AAA TOW?)
USE a known good battery from other car yet.
all fail check key line
hit starter on side with hammer? (sorry a tool)
btw dead batteries fail all tests. so charge it first then test it or be out $130 for nuttn.
(makes car stores rich, not now..)
Dec 04, 2015 | 2007 Jeep Compass 2.4
My 1997 GEO Prizim has power when the key is inserted but won't turn over. When you turn the key it only makes one click. What could be the problem ?
the starter uses huge currents. 20x head lights.
try my list.?
  1. battery terms clean?
  2. does it jumper cable start? (or charge battery or barrow one)?
  3. Head lights work, ? not dim.
  4. is car auto trans. yes, then crank in neutral. yet?
  5. if car is stick? shift then, bypass clutch switch?
  6. does hot wiring the starter solenoid, allow it to crank.?
  7. yes, then key line is dead. no the start is dead.
  8. alarms added? or remote start bs or other hacks to cars primary wiring>?
Sep 13, 2015 | Geo Cars & Trucks
2009 Jeep Compass won't crank. Any answers ?
sure,
but what transmission, ill guess automatic.
Check fuses first? always first !
Check engine light on,key on, no, fuses.....
does it crank in NEUTRAL? (it will (can), per opr. guide)
does it?
scan it yet to see if there are TRS switch errors>??
do jumper cable jumps work>? off a running car, AAA tow truck like?
yes, then the battery was dead, or discharged.
no? then key line is dead. if hot wiring starter fails.
if hot wiring passes , then the key line is dead. TRS switch.
got tools or just want wild guessing?
my guess is wild.
so jumper cable it and report.
Mar 14, 2015 | 2009 Jeep Compass
What caused my 2010 jeep liberty to go dark and dead after turning the key
Posting the same question over and over does not increase likelyhood of an answer.
Jun 30, 2014 | 2010 Jeep Liberty
Starter dead
Daniels Auto Repair American Towing
send them a message they may be able top help!!
Jun 18, 2014 | Ford Focus Cars & Trucks
Just put the key in our 2006 cadillac dts and cannot remove it. Car is not starting. Battery possibly dead? Help please
I need more details. Is the car engine " cranking' over at all, very slowly ect.
Do you hear any sounds when you turn ignition to start ?
Are the lights coming on in the dash when you turn on ignition ?
Do your headlights come on ?
Please let me know.
Feb 07, 2010 | 2006 Cadillac DTS
The car alarm and key pad will not disarm and the car will not start.
Normal system operation - when the burglar alarm is active, the starter circuit is disabled. Is the battery dead or weak in the keyless remote? Also, is the remote you have been programmed for this vehicle? If the answer is 'yes' to both questions, replace the battery in the remote. Otherwise, place your ignition key in the ignition and turn the key to 'run' (or 'ON") wait 5 minutes, the vehicle should start (if the battery isn't dead).
May 22, 2009 | 2003 Hyundai Tiburon
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
310 people viewed this question
Top Safe International Locks & Locksmithing Experts
Marvin
Marvin
john h
Sheldon Dedek
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
