Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
A
Anonymous Posted on Jul 15, 2014
Drum is loose and making noise while running - Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Jorgie the appliance guy
Level 3:
Top Expert:
  • Whirlpool Master 5,639 Answers
  • Posted on May 07, 2015
Whirlpool Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1522468
Points
32630
EITHER BAD FELT GLIDES, ROLLERS OR DRUM BEARINGS
drum is loose and making noise while running - 24833818-k4ataymuwmgrdb2rqqdy5pxt-5-0.jpg
24833818drum is loose and making noise while running - 24833818-k4ataymuwmgrdb2rqqdy5pxt-5-9.jpg
drum is loose and making noise while running - 24833818-k4ataymuwmgrdb2rqqdy5pxt-5-20.jpg8-k4ataymuwmgrdb2rqqdy5pxt-5-14.jpg" alt="24833818-k4ataymuwmdrum is loose and making noise while running - 24833818-k4ataymuwmgrdb2rqqdy5pxt-5-27.jpg
Fisher and Paykel Dryer making noises after moving it
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Makes a loud noise when running
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Apr 23, 2016 • Dryers
When I start my sst16 and it is running it makes a horrible clicking noise. Can someone tell me why it is doing this and how to fix it. Thank you in advance.
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Mar 23, 2016 • Dryers
It just started to make a squeaking sound. Like metal rubbing on metal.
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
2yr old maytag maxima dryer gets louder and louder after run 30min. prob. repeats after cool down and running again. Vent is clean new pipe, no error codes. Sounds like a surging vibration.
DRYER MAKES NOISES.
The blower:
The bearings:
How do I fix my whirlpool cabrio dryer model wed6200swi so that it stps the noisy squealing sound when it runs?
DRYER MAKES NOISES.
The blower:
The bearings:
GE dryer DCVH515EFOWW thumping noise after heats up. Recently replaced front drum bearing and slides which fixed squeaking. Now having rhythmic thumping (no squeal or squeak).
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Aug 18, 2014 • Dryers
My kenmore 84052 is making a squeaking noise
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Kenmore he4t makes a whinning noise when it is not running
DRYER MAKES NOISES.
The blower:
The bearings:
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
