Question about Carrier TSTATHCP Programmable Thermostat Air Conditioner
960 manual I have a carrier thermostat model 960 120032-2 and the display is very dim . . . Is this a battery problem? Do I need a new thermostat to make the display more readable??
Cris Sparks
    Sergeant:
  • 338 Answers
Yes change batteries.
Posted on Jul 16, 2014
2 Related Answers
Anonymous
SOURCE: Carrier Thermostat Model TSTATCCPB501 ER code
I gave up and called a local HVAC business. This thermostat is discontinued and a new one will be purchased and installed.
Posted on Dec 16, 2008
Anonymous
  • 553 Answers
SOURCE: install programmable Carrier thermostat
you'll be needing an assistance from an A/C technician, If this a progammable you want, some configuration need to be done and a technician can only do that.
You can search the web for a local carrier dealer nearest to you
Posted on Nov 05, 2009
I have Carrier thermostat that we lost manual for. Model is 960-060170-30-R. We are trying to get the fan from permantly running to auto position. Any help would be great or a link to the manual
I believe that is the edge tstat and what Im finding is you can only control the fan when your not running a program. if you have occupied and unoccupied settings it may be under a business program rather than residential. Google the edge manual and follow steps to remove the programming. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 08, 2018 | Carrier Heating & Cooling
Digital carrier thermostat reading P- on display. Any idea what this means
Some thermostats run on their own batteries, but some need power from the furnace to display, check this first. "P" may mean power.
Nov 22, 2016 | Carrier Heating & Cooling
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Carrier Thermostat 33CS450-01 User's Guide ...
homeappliance.manualsonline.com > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
Sep 10, 2015 | Home
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
My Carrier thermostat keeps running my heater. I adjusted the temp lower but it didn't stop running. I changed the mode to off and then it stopped. However, the mode button was insensitive and I had to...
sounds like that thermostat has reached the end of the road. My advice is to replace the thermostat because its 6yrs old and is worn out due to continued use. programmable t-stats have a wide price range to meet your needs. and the batteries in a thermostat are only for back-up power because the thermostat runs off of a 24volt power supply from the air handler.
Nov 28, 2010 | Carrier Heating & Cooling
Install programmable Carrier thermostat
Nov 05, 2009 | Carrier Heating & Cooling
Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
Apr 01, 2009 | Carrier TSTATHPP 7-Day Programmable...
Dec 15, 2008 | Carrier BCA101R Air Conditioner
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Heating & Cooling Logo
1,421 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
