Car Audio & Video Logo
Question about Jensen Car Audio & Video
How to bypass jensen
How do I bypass the parking brake feature on my Jensen VX7020 so my son can watch movies while I drive?
Posted by Bryan Thompson on
s_a_goluboff
    New Friend:
  • 11 Answers
There is a wire which grounds to your parking barke mechanism from your system. You must move this to another (fill time) ground.
Posted on Jul 15, 2014
5 Related Answers
Anonymous
SOURCE: bypass brake for a jensen vm9311
Don't pay for it....Just read it:
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
(Sorry Jack Sap, but this stuff should be free...)
Posted on Dec 14, 2007
Anonymous
  • 1586 Answers
SOURCE: jensen double din dvd monitor uv8020
Here's what you need to know: DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In mine, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in the manner of the e-brake cycle I mentioned earlier.
Posted on Sep 13, 2008
zappanut
ZappaNut
  • 960 Answers
SOURCE: Jensen vm9512hd e-brake bypass
the pink wire on the unit is for the E-brake.... ground it out somewhere and that will bypass the brake and fix the problem.
Posted on Nov 16, 2008
Anonymous
SOURCE: bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
Anonymous
SOURCE: Need to bypass parking brake feature on Jensen VM9512HD
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
Posted on Jun 30, 2009
How do I access hidden menu or bypass brake dvd warning on Jensen VX7021?
http://www.uneeksupply.com/Jensen-VX7021-Radio-Parking-Brake-Bypass-to-watch-video-in-motion-_p_41815.html
this is what you need to bypass the sfety feature. Note this is for off road or show purposes only. Having video playing within view of the driver is ******* in moststates and is dangerous.
Start up volume way too loud! The answer here is to push in volume button to set..my volume button when pushed in sets mute and on/ off
Annoying issue but honestly, I have no idea how to operate your "Jensen VX7020 6 2 Inch MultiMedia Bluetooth" but logic says you should read instructions. Read these instructions
http://www.jensenmobile.com/docs/common/VX7020/VX7020_IM.pdf
Watch these videoos, maybe get some hint
Jensen VX7020 6 2 Inch TFT Car Stereo 2 0 DIN MultiMedia Receiver with...
Jensen VX7020 6 2 Inch TFT Car Stereo 2 0 DIN MultiMedia Receiver Review
also some info at this website. Check it:
vx7020 manual
7helpful
6answers
I just purchased the VX7020 and went to Settings-Language-typed in 5,4,3,2,1,0 but the menu never came up. Any ideas?
Whats the brake bypass code for jensen 9215bt
I have no idea what you are talking with the "code". It's a Jensen!!!Attach the parking brake wire to ground and watch a movie.
11helpful
2answers
When I try to play a movie, I only see the warning sign on the screen. I can hear the movie playing, but the warning will not go away. This is even when the vehicle is in park. Any ideas what may be wrong?
Bypass Code
1. Go into Am/Fm mode
2. Hit "setup" on the remote control
3. Enter 543210 on the remote, listening for the beep for each number entered
4. A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen
5. Select Brake bypass to "ON" and hit the "X" near the bottom of the screen
2answers
Bypass parking break feature on the Jensen VM9311TS
You can purchase an aftermarket bypass kit from electronics store or off ebay... But hey, be careful, no watching movies while driving... K
7helpful
9answers
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
3helpful
4answers
Bypass the parking brake for vm9412 jensen
Select Language.
derek
1helpful
6answers
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
2answers
Bypass brake for a jensen vm9311
the wire is pink and say parking on the wire.
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
