Depending on where it is leaking there are several places. I will illustrate in this drawing. The biggest problem on "non-water line models is the silicone elbows. Check them first. Unplug the brewer and remove the top burners and cover. Then get a pitcher of water and plenty of towels then start slowly pouring in the water and see if is starts filling up the top of the tank lid with water. if it does. remove the pour in tank, then remove the rubber/silicone elbows and if they come out easily, they are bad. Replace them. If you are going to replace them also replace the small 1/4 inch line that goes to the fill basin from the tank. It is about 8" long. Good luck.
