Question about Polaroid Audio Players & Recorders
How do i turn on my Polaroid Shuffle 4GB MP3 player?
I do no know how to turn it on or off.
Adriel Ramirez
    New Friend:
    Problem Solver:
  • 5 Answers
There is a led light in the upper right corner of the front. The controls are on the large round button in the center. To turn in on, press in the center of the button; the device will turn on and playback will begin. To turn it off, press AND HOLD the center of the button until the LED light flashes several times and then turns off.
To play, press the center of the button and the LED should come on and stay solid. To pause, press the center and the LED will blink once a second Press again and playback will resume.
Think of the big button as a clock face. Press at 12 for volume UP. Press at 3 for next track; HOLD for fast forward. Press at 6 for volume DOWN. Press at 9 for previous track; HOLD for rewind.
For shuffle, press at 12 and 6 together and hold for 2 full seconds. The LED will flash 4 times to show you are in shuffle mode. To go back to normal playback, press at 12 and 6 together for 2 full seconds and the LED will flash 2 times to show you are back to normal mode.
Posted on Sep 20, 2014
5 Related Answers
Anonymous
  • 62 Answers
SOURCE: Cant find the reset button on my MP3 player
Hello, and thanks for using FixYa! The reset is actually format. Go into the menu and find format. Accept the format device and it will reset everything. If this was helpful, please take a moment and rate the solution! Thanks, and Good Luck!
Posted on Jan 13, 2009
YourZEN
YourZEN
  • 820 Answers
SOURCE: iRiver E150 Shuffle
Starting from the main menu.
Select Music.
In Music mode: Press and hold the > button to view the Options screen.
Select Play Mode.
Under Play Mode: select Shuffle or Shuffle + Repeat.
You can also look this up in the E150 manual. Download the English.zip file from next page:
http://www.iriverinc.com/lounge/loungeView.asp?selectPart=03&findWord=&sno=985&page=1&cateCode=03
Unzip the zip file, with WinZip or WinRar, to view the manual in pdf format, that can be opened with Adobe Reader.
Posted on Jul 24, 2010
Testimonial: "Thank you so much. I have been scouring the internet for days with no answers. It worked perfectly, very happy now. Thank you! (:"
Anonymous
SOURCE: I need a driver for
you dont need a driver. you got the driver w/installation cd.you need an icon(shortcut) on the desktop so you can find and start the program to convert or encode the vid files to the correct format.btw, on the box of mine it is "pmp280c-4". the problem is that when the setup disk installs the software it DOES NOT put the icon (shortcut) to the software on the desktop like it says it did or will! the software and device are ready but one cant find the program. i have win vista and i found the program with: start button on the taskbar (at the far left), click it and then click "all programs" and then look for "media player utilities 5.20". click that, and then right click "video converter" and then "point" to "send to" and then click "desktop (create shortcut)". this will do what the setup program did not do-it puts the shortcut on the desktop.
Posted on Nov 02, 2010
Anonymous
SOURCE: I have a polaroid music
Just buy another mp3 player ******.
Posted on Nov 17, 2010
Anonymous
SOURCE: i have a polaroid mp3
Ok, I had this problem & finally fixed it! Hold the power button till the word "polaroid" come across the screen, wait a few seconds to make sure its on. Push the bottom right corner of the screen, push the middle of the left hand of the screen next, go down to about the middle of the screen and start pushing towards the right. If it doesnt work right off then keep trying cause it does work!
Posted on Jan 15, 2011
My Philips TV turns on and back off instantly. If you know what could be wrong let me know please. Thank you.
Hate to tell you this but mine did the same thing,took it to a shop,said it would cost way more than it's worth,I let them keep it.
Oct 31, 2016 | Philips Televison & Video
I NEED TO KNOW WERE DOES THE TURNING SIGNAL FUSE IS ON MAZDA MILLENIA 1999 MY TURNING SIGNALS DONT TURN ON
Do they all not work,or just one or two?.turn the ign key on.and recheck
Sep 12, 2014 | Cars & Trucks
My beltronics police radar turns on but turns back off and I don't know why
The new Rader Unites that law inforcement use has a built-in
Blocker, Unlike the old units you could pick up the signal .
This keeps people from knowing when they are used.
Apr 21, 2013 | Vehicle Parts & Accessories
Voice Over is on. I have an iPhone 4. I don't know how it even got turned on but don't know how to turn it off. Is there something in the settings??
in the home screen double tap settings and scroll using three fingers and double tap general again scroll using three fingers double tap on accessibility and double tap voice over and double tap it to switch off
Mar 23, 2013 | Apple iPhone4 4G iPhone 4
TV automatically turns off. unpluged the tv and
Hey i am having the same exact problem with my same exact tv. If you have already solved your problem I would love to know how u did it. I know you posted this a long time ago but if you havent gotten it fixed yet, if I fix mine i will let you know. Thanks.
Aug 03, 2010 | Toshiba 65H84 65" Rear Projection HDTV
Asking for a security on my nokia phone
My cell phone frequently turned off and i dont know why then last time I turned it on,it was asking for a security code and i dont know why..i dont evevn know my security code..i already tried 12345 but it doesnt work..please do help me..my IMEI is 355029000657957..thanks in advance..
Oct 08, 2009 | Nokia 1100
2002 nissan altima it work turn over
you need a light tester to see ifthe starter is getting power and when you turn the switch to see if it is working the solinoid without this informantion there is no way to help you trouble shootthis issue.
Jun 28, 2009 | 2002 Nissan Altima
Turning off traction control on a 2006 grand cherokee
there is no option to turn it off. if, however, you remove the abs fuse you will have disabled the track control as well as the abs.
Mar 29, 2009 | 2006 Jeep Grand Cherokee
I need the manual or instructions to my camera.
i dont know how to turn on the light/flash of my digital camera,even i put in the flash mode it doesnt work.it is a primier digital camera.
Jan 13, 2009 | Cameras
How do you manuall turn it off?
It will only turn off by itself. It does not have an off switch.
Dec 07, 2007 | Sims SVR-S1335 Digital Voice Recorder
Top Polaroid Audio Players & Recorders Experts
Tom Chichester
Bill Boyd
Are you a Polaroid Audio Player and Recorder Expert? Answer questions, earn points and help others
