For some reason when I go to call my mom or somebody my phone call is switched over to Verizon Wireless and it wants my phones pin number or my VISA card number. I paid for my phone card and did a refill yesterday and everything was fine until this morning. I can't even get on the Internet.
SOURCE: n95 sim problem
try checking your sims terminals if theirs any obstruction or one or any o the terminals doesnt contact w/ the sim. or try putting a folded paper like the size of your sim on top of your sim...
cause common cause of insert sim is that it lost its contact w/ your sim terminals..
SOURCE: Sony Ericsson Z525A-COPY PHONE NUMBERS TO SIM CARD -BLANK SCREEN
to retrieve your numbers you would need to follow these key strokes...
center, toggle down (1 time), center, toggle up (2 times), center, toggle down (5 times), center, toggle down (5 times), center (3 times)
then wait for quite some time...it takes a while to copy all of the contacts...I would say anywhere from 5 to 10 mins...
this should work to save your contacts.
To save your pictures (and any other data you might want to retrieve) you could buy Sony's data cable for the z525a. I haven't tried this but it should work since that is what the cable is for.
Its called a DCU-60 USB data cable, and is listed as being compatible with the z525a.
SOURCE: Razr v3x screen suddenly won't work
check the oem ribbon that runs to screen. the design of phone hinge is faulty, and usually cuts the ribbon that runs up to the screen after months of openings and closings,preventing it from lighting up. sometimes its the earpiece wires on the ribbon that get cut which prohibits u from hearing anything when u hold the phone to your ear and u have to switch to speaker...bummer..sooo my friend, CHECK THE RIBBON.
SOURCE: Does not get past the Verizon screen when turning the phone on.
I hate to be the bearer of bad news but the only thing i would say try is taking the battery out for about 30 seconds. putting it back in and trying again. if it does not turn on then i'm afraid the phone will not come back. It's a somewhat rare problem but does happen.
Unfortunately all information is gone unless you had downloaded backup assistant.
