Samsung UE40F6400 - 40"" LED-backlit LCD TV - Smart TV HD TV 1080p, 40 inch 101 cm 16/9, 200Hz, Freeview, 3D Ready, Ethernet, HDMI x4, USB 2.0 x3, Integrated WiFi Logo
Z
Zlaja Posted on Jul 15, 2014
How to switch off color diagnostic mode, Samsung Tv
When I turn on my TV tv is just cycling /changing colors .Green, Red, Black... on full screen. It looks like some colour diagnostic mode or something like that.Tv is MSart Samsung 40 inch, model no is 4500 or 5000
terry peters
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Aug 31, 2014
terry peters
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3005
Points
6
Go into tools on your remote
  • terry peters
    terry peters Aug 31, 2014
    go into tools on your remote
5 Related Answers
HDTV GURU
Jay Henderson
  • 261 Answers
  • Posted on Mar 22, 2008
SOURCE: New Samsung Plasma HDTV
That is what is called BURN IN or as the manufactures call it "IMAGE RETENTION". Basicly what this means it that you have been putting more hours on the part that is darker the smaller part, or the 4x3 picture or the square part. And, basicly the part that appears to be lighter is "LESS" worn out than the other part of the plasma tv. There is no fix for the problem, But if you go into the menu and select "BURN-IN" OR "Pattern sweep" or WHITE Screen than you will see exactly what i mean. Now, you can keep it on this pattern overnight if you would like, but i suspect it will not cure the problem, but lessen the effects of it. But keep in mind, you are reducing the life of the complete panel when you do this. Not that it is bad to do this. If you have anymore questions don't hesitate to ask anymore questions. The better fix is to Switch over to the "Dish Network and than you can format the screen on any channel in any mode. Superior product to cable. Have a great day. And watch out for the snow storm coming. GURU JAY
A
Anonymous
  • Posted on Jun 19, 2008
SOURCE: Black/Dark Colors Fuzzy w/Red Pixel Outline
I have the same problem too....
Anonymous
  • 59 Answers
  • Posted on Jan 10, 2009
SOURCE: color problem
hi it could be a loose cable in the back of the tv
Anonymous
  • 98 Answers
  • Posted on Feb 06, 2009
SOURCE: Samsung LNS 4051D color problems
1.T-con board or related cables problem -- 60%
2.replace Main Board -- 40%
Chi Chu
  • 8457 Answers
  • Posted on Oct 10, 2011
SOURCE: HI, I have a 40" Samsung Flat Screen TV (Model:
This tv 100% have problems with the main logic Tuner signal board that the board where the tv board that the tv incomming broadcasting signal wire plug into it.This tv might also have problems with the T-Con board too.The tv T-Con board that the tv board sit in the middle at the bottom of the tv LCD screen panel to project tv pictures pixels dots to the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com buy a whole refurbish main logic Tuner signal board and or a refurbish T-Con board for the replacement too.
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
1helpful
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
2answers
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
2helpful
2answers
My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
2answers
Screen is black two green blinking lights 1 red
Ur power supply needed to be rebuild,like changing capacitors,extra..Or buy a new power board,because it dead.
1helpful
Sony Bravia KDL 40 HD
it's in a service test mode. have you unplugged the tv? that should reset the tv..if you still have problems after ..it will need repair.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
