Question about Linksys Wireless-G WRT54G Router
Usb tv received which will work with windows 8?
  • ka4iup
    ka4iup Jul 15, 2014
    Hi Anonymous, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? All types of equipment, and better idea of what information you need. This does not sound like a router problem.
Have a dynex optical mouse model # DX- PWLMSE how does it connect
The Dynex DX-PWLMSE uses a 27 MHz frequency wireless connection between the mouse and a specific USB receiver. For the specifications, see https://www.dynexproducts.com/pdp/DX-PWLMSE/8632063 .
To use the mouse, you need to press the Eject button behind the scroll wheel. This lets you open the battery/USB storage compartment. Put two AAA batteries into the mouse. Then remove the USB adapter (it's between the two battery slots). Close the storage compartment and put the USB adapter into an available USB 2.0 slot on the computer with a version of the Windows OS above Windows 98. (Note: the specifications I see indicate Dynex wrote drivers for Windows Vista. It may not work with Windows 7, 8 or 10.) Make sure that the computer is on and can get driver updates from on-line sources. Turn on the mouse and it should auto-pair with the receiver. If there is no response, try pressing and holding the connect button on the bottom of the mouse.
I'm not aware of any vendors that sell the USB receiver for this mouse. The manual for the DX-PWLMSE is available from Manuals Lib: https://www.manualslib.com/products/Dynex-Dx-Pwlmse-Wireless-Optical-Usb-Laptop-Mouse-4908.html .
I hope this helps.
Jul 16, 2018 | Dynex Computers & Internet
Tip
How To Fix Usb Device Not Recognized in Windows
Sometimes, when you plug a USB device to your computer you may receive a Usb Device not recognized or usb port not working pop up message. If your USB device is not detected, then we will show you how you can troubleshoot usb not recognized error.
Follow Quick Steps To Resolve Usb Not Recognized Error Windows:
Press "Windows" + "R",a run window will open
In the "Open" box of the run window type "devmgmt.msc" and press "Enter"
This will open theDevice manager
Click on the arrow besides "Universal Serial Bus controllers"
Right click on each USB port and then click on "Uninstall"
Restart your computer and wait for Windows to re-installs USB controllers.
Try to connect yourUSB deviceagain.
How To Fix Usb Device Not Recognized In Windows 7 8 1
on Jan 28, 2015 | Computers & Internet
Hub usb windows 10
any usb hub will work with anything usb
Nov 21, 2017 | Computers & Internet
Blaupunkt 40/148 tv. how do i record programmes to usb ?
I could not find an owners manual for this TV but if it is like most TV's usb is for playing media, Not recording. I found a site that talks about your TV. The first reviewer explains the usb is for watching (not recording). I have a different TV and same holds true. IF you really want to record TV and have a computer with Windows 7 or Windows 8 you have capability to record to the computer and then move it to a usb to watch it elsewhere.
Customer reviews for Blaupunkt BLAUPUNKT 40 148
I hope this helps.
Jan 29, 2015 | Televison & Video
How to use it on Win 8. It worked on Win 7 but now loads but will not tune in TV and does not recognise DAB or FM.
Make sure it is installed correctly, it may need to run in Windows 7 compatibility mode under Windows 8(.1) for the TV tuner to work.
Jan 03, 2015 | Computers & Internet
Need windows 8 drivers.
This USB TV tuner only supports Windows 2000 SP4, XP SP2, and Vista. it does not mention supporting windows 7 or 8.
May 07, 2014 | VuPoint Solutions USBTVDG26VP USB TV Tuner
Sound is not working for Dany u1050 usb tv device in using win8
Download and install a Windows 8 compatible driver from the URL below.
www.dodownload.net/drivers/dany-u-1000-1050-2000-usb-tv-drivers.html
Jan 25, 2014 | Computers & Internet
Pacific Image PrimeFilm 1800u Film Scanner : is there a Windows 8 driver out there somewhere? Can anyone offer some help in finding it?
PrimeFilm 1800u will not work on Windows 8.
Here is the response I received from the company for the question:
Where can I get drivers for windows 8? Windows 7 drivers are not working on Windows 8.
Response:
Hello, This scanner will not be supported on windows 8, all of our USB 1.0 technology scanner will no longer be supported beyond Windows 7.
Wendy
Dec 19, 2012 | Pacific Image PrimeFilm 1800u Film Scanner...
How do i connect my wireless i.t.works optical mouse model MWO03 to my eee laptop windows 7?
Follow these steps :
1.
Check to see if your laptop supports wireless technology (Bluetooth, 802.11 or other). If it doesn't, you will need a wireless receiver. If it does, verify that your laptop is compatible with your wireless mouse, which could use either Bluetooth technology or a radio signal.
2.
Unpack your mouse and open its battery compartment. The wireless mouse won't receive any power from the laptop, making batteries necessary.
3.
Add new batteries to the compartment. Make sure that the + battery end is inserted into the + niche in the compartment.
4.
Place the mouse where it is easy to use and least stressful on your fingers.
5.
Place your wireless receiver appropriately if your laptop doesn't support wireless technology. The receiver should be kept at least 8 inches away from the laptop or any other object that would cause any interference.
6.
Place the wireless receiver anywhere from 8 inches to 6 feet from the mouse.
7.
Insert the driver CD into your laptop and follow the instructions to install the software for running the mouse.
8.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop. If you do not have a free USB port, simply use an external USB hub for more ports.
Nov 07, 2010 | Computers & Internet
USB HUB, Receiver & Keyboard
dude
Try to update windows xp service pack, i guess usb root hub drivers is missing, when you updated windows xp they will get fixed by itself
Dec 18, 2008 | Microsoft Windows XP Professional
Linksys Wireless-G WRT54G Router Logo
153 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
