Question about Power Acoustik PTID-8300NR Car Video Player
Need wiring harness for ptid-5000 - Power Acoustik PTID-8300NR Car Video Player
2 Related Answers
Anonymous
SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
Posted on May 05, 2009
ahaviland28
amber haviland
SOURCE: Power Acoustik PTID-4007
I would check if your vehicle has a factory amp. Often times they must be bypassed. I had a similar problem with my 1998 Mits. Eclipse Spyder. I had to wire all the speakers directly.
Posted on Dec 25, 2013
NEED A PRICE
I'm interested in the wiring harness that you have .. If you want, I can give you good price for it.
call or text : 8324206785
Apr 18, 2012 | Power Acoustik PTID-5850NR Car Video...
Installing a ptid-8960 power acoustik into my new 2011 mazda 3 what wires should connect or can i even install it without getting the wire harness adapter to make it like the same connections not quite...
You absolutely should use a wire harness for this installation. Not using one would require you to clip the wires to factory radio connector, making re-installation of the factory stereo nearly impossible. Even worse, you would have to wire the connector that came with your PTID-8960 deck to the clipped ends. This task would be nearly impossible, as the factory wiring is too short to extend out of the dashboard where you can work with it easily.
Save yourself the trouble.
I tried finding the exact item you will need, but it seems the Mazda 3 comes with stereo options that could affect which wire harness you'd require.
Here is a link to Crutchfield: http://www.crutchfield.com/p_120707904/Mazda-Receiver-Wire-Harness.html?tp=2977&tab=other_items
You can use their site to select your car and installed options, and they will return products compatible with your vehicle.
Jun 14, 2011 | Car Audio & Video
Missing wire 4 from manual....whats the name of wire
just had the same problem-it does not come with the stereo or even the DTV1 box, it only comes with the NAV1 unit. Luckily I found a local stereo shop that sold me one out of ther NAV1 box since I only bought the DTV1 box with the stereo and I needed it. So hopefully you will have teh same luck , either that or you will have to buy it directly from Power Acoustik.
May 23, 2010 | Car Audio & Video
Power Acoustik PTID-4007 Okay, so I checked my radio fuse, it's fine. Checked for constant and acc 12v. and they are there. fuses on harness are good. I spliced my adapter harness onto the PTID-4007...
i have Power Acoustik PTID-4007 my problem is not turn on lcd not out audio but yes is take cd and out cd, the screen is move in three postion. help me please
thanks
Mar 08, 2009 | Power Acoustik PTID-4006T Car Video Player
Help i need a wire harness for power Acoustic dvd player
Jan 24, 2009 | Power Acoustik PTID-5300 Car DVD Player
Power Acoustik PTID-4005 BYPASS BRAKE
Just ground you brake wire directly to the metal frame. It should work fine. Goodluck.
Mar 03, 2008 | Power Acoustik PTID-4005 Car Video Player
Power Acoustik PTID-8300NR Car Video Player Logo
62 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
