Sounds like a loss of green--I am in USA and Scart term not used here but I am aware it began as internet slang for Component hookup--which does use a Green, Red, and Blue input cables---if that type then suspect no green from source or cable bad etc.
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one.
If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
its not possible till you get that rec colour refilled in your colour cartridge or replace the colour cartridge.so you cannot print black as the printer is not been able to end its cycle as the cycle is getting break at the colour cartridge.its very common problem faced by many users but no other option except replacing or refilling the cartridge.
thanks.
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
