Did you try removing and reinstalling the new print cartridge? If it still does it, try powering it off, unplug it, wait 5 minutes then plug it back in. If it still does it, you could try a reset on it.
You can't use the printer without all the inks installed on it. If the retailer store don't have the ink that you're missing try to check online for the ink cartridge that you need. Try to go on this website for the inks availability.
Ink system failure indicated that ink delivery mechanism of the printer is experiencing problem. We need to do below resets for this printer to fix this issue.
Solution 1:
Press the On button to turn of the printer.
Unplug the power cord from the back of the printer and from wall outlet or surge protector.
Removed all the ink cartridges
Wait for 2 minutes
Connect the power cord and turn the printer On.
Install the ink cartridges
(Please go to solution 2 if the problem is not resolved)
Solution 2:
Remove all the ink cartridges.
While the printer is ON, unplug the power cord from the back of the printer.
Press and hold OK and Cancel button, while holding these buttons connect the power cord.
Release the button after 20 seconds.
Turn on the printer if it goes off and install the cartridges.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution Press the On button to turn the printer off. Unplug the power cord from the back of the printer. Remove all the ink cartridges. Wait two minutes. Plug the power cord into the back of the printer. Press the On button to turn the printer on. Install the ink cartridges when prompted. If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
