Question about Pride Mobility Products Revo (3wheel)
Scooter will not move. Batteries and charger are fine. Controller was replaced. What could cause the problem
meezermagic
    New Friend:
  • 6 Answers
Have you checked that the freewheel lever is properly engaged? You will find it somewhere near the rear wheels. If it isn't engaged the scooter will not move when the power levers are pressed. It would react like a car in neutral ie nothing would happen.
Posted on Aug 22, 2014
2 Related Answers
Anonymous
  • 26 Answers
SOURCE: wont charge
the batteries have failed or the fuse in the charger
ted
Posted on Apr 15, 2010
AriEl
  • 32 Answers
SOURCE: New batteries and charger but will not recharge batteries on Pride scooter
To recharge the batteries the have to be alkaline and make sure they are facing the right way
Posted on May 26, 2012
I HAVE A NEW gO-gO TRAVELER WITH NEW BATTERIES AND IT WONT MOVE
Who installed the new batteries? There could be a loose
connection or a disconnected plug to the controller when
the batteries were swapped out.
Jun 29, 2015 | Pride Mobility Products Go-Go Elite...
My pride go go elite traveler 4 wheel stops randomly often with no beeps. I have replaced the throttle, the speed pot, the brake, and the batteries check out fine.
You may have a loose connection at one of the harnesses or connectors. If there are no codes you may have a bad controller or loose connection at the controller. Slow speed problems may be motor or motor brush problems you can diagnose by visual inspection or a voltmeter. Load test the new batteries and the charger output. Block it up and run it checking and knocking all the components until it quits. I have seen a dragging brake caused by a melted controller harness at the controller connector cause a similar problem. Hope this helps.
Aug 18, 2012 | Pride Go Go Elite Traveller Plus HD 4...
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
My electric mobility scooter is froze up the needle showing battery charge goes over to zero but it will not move the temp is -8
There is a gel inside the batteries that may be frozen or too thick from the cold to allow the power to flow properly. Bring the scooter inside and allow it to gradually warm up to see if that will allow the current to flow from the batteries. Do not attach the charger until the batteries have thawed a bit as this may cause damage to the cells. If the controller warms up too fast, condensation may build up inside it which can damage the electronics. Slow and steady wins the race.
Dec 26, 2010 | Health & Beauty
Charging problem and also it never stands for a long time , new charger is again given from the company but no use , pls help
If you have recieved a new charger, are charging the batteries for 8-10 hours and the scooter has not been stored for a while, the batteries may need to be replaced. Do you have any flashing lights on the controller? Is there any noise or vibration when you operate the scooter that might cause fast battery drain? Batteries usually last 1-2 years with proper self maintenance; if your batteries are older than this they may just be worn out and need to be replaced.
Oct 11, 2010 | Health & Beauty
I have a gogo scooter it bleeps once than cuts out I have to turn it off and back on for it to move
probably a dead battery or a bad battery will move you till the controller gets to a threshold voltage then it beeps and stops , testing this is easy turn on the scooter adjust the speed control to the lowest setting then start riding the scooter at full throttle then start turning up the speed controller if that produces the problem then the batteries need charged or replaced
Jul 01, 2010 | Pride Mobility Products Go-Go Elite...
I have a scooter simerlaer to the 4 wheel mayfair scooter and it was working fine when we used it when we got it but tested it a few months ago also fine and now it just doesnt work the batteries arent...
Hi. I have seen batteries before that have dried out. Once this happens, they are just about kaput.
There are not many machines around now with "wet " batteries such as these. The sealed lead acid and gel batteries are sealed. When the batteries are being charged, these batteries maintain an internal pressure of 1 to 2 pounds per square inch. This recombines the gases back into water in the cells.
But you must use the charger supplied with the machine, as over charging will cause the battery to vent gases and eventually dry out.
The loose wires on the controller need to be a firm fit. If the terminals are damaged, it pays to fit new ones.
Most likely to be the batteries causing the fault. See if you can borrow a couple of reasonable batteries to try. This will let you know if there is any other faults.
Good luck. Neil.
Jun 09, 2010 | Pride Value Line Revo Scooter 3 Wheel
AXS Mobility scooter loses battery power quickly.
hi , two problems can cause this,
1. batteries are weak, is the charger ok ? just because it 's green does not mean the charger is ok, can you validate the charge, try some other batteries ?,
2. Brake be activated or on at all times,
The best way to prove this is to remove the brake mech from the side of the motor completey now try the scooter, if the problem goes away then check the resistance of the brake, is it open or shorted ?
If you feel the brake, batteries and charger are working ok then the controller must be activating the brake and this is the fault but please double check the voltage on the brake leads.
Regards
GeWiz.
Jan 11, 2010 | Pride Mobility Products Go-Go Elite...
On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Jan 25, 2009 | Razor E100 Electric Scooter
Pride Mobility Products Revo (3wheel) Logo
141 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
