Question about Frigidaire Affinity ATF7000ES Front Load Washer
If you have a button jammed what do you do
It shut off ever 30sec.
I have a Sportline TraQ Pedometer model 370. It does not say in the manual how to shut it off. How exactly do I shut it off?
Some Pedometers turn off automaticaly once they stop moving after a while. Others just require you to press and hold a button for a while. Leave it alone (eithout movement) for 5min, if it dosn't turn off try holding a button for 30sec.
Aug 30, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
Lexmark printer 3600-4600, after paper jamed and took paper out . but it still shows " paper jam " all the time . And printer seems not remove "paper jam" away even reconect box jection behind ...etc....
check that their is no pieces of paper broken off in machine and that all the paper sensors are not still jammed and moving freely then switch off machine for at least 30sec then switch on should work if not check again and make certain all covers and doors are properly closed
Oct 13, 2010 | Lexmark X2600 InkJet Printer
My iphone fell screen not responding to touch
Try holding the POWER and the HOME button at the same time for at least 30sec...that should Force Shut it down
Sep 22, 2009 | Apple iPhone 3G
All of a sudden it is telling me I have a paper jam when I try to fax out. All the pages go through but after the last page goes through the machine runs just a little longer, then tells me there is a...
restart it... try this after you turn it off unplug it then hold down the power button for 30sec. and then plug it back in and restart it... I hope this works. what are you trying to do is to get rid of all the static in the printer chips which could trigger this problem. good luck
Sep 17, 2009 | Brother MFC-8860DN Printer
Sun roof stuck open
It seems to be that your cables have come off track or have became broken and/or bound. I'm assuming that this is the binding sound u have described.
Jul 15, 2009 | 2004 Chevrolet Tahoe
Pixar disney cars tv turns on but shuts off after about four secs
The DVD is causing the problem, disconnect the plug that lead from theDVD to the main board and see if set will stay on.
Jul 07, 2009 | Disney CARS 14 TV/DVD Combo
Car stereo shuts off
IS IT A GOOD QUALITY CD OR A HOMEMADE ONE ? SOMETIMES THE HOME MADE DISC DO NOT GET FINALIZED AND THEN THEY WILL ONLY WORK ON THE COMPUTER THAT MADE THE DISC
RATE ME PLEASE
Apr 16, 2008 | Car Audio & Video
Washing Machines Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
