Question about Goodman CKL24AR24 Air Conditioner
I have a carrier AC unit Model no. 52SQC312301aa .when i turn on it buzzs then clicks off nothing else works
J Rosado
  • 1,202 Answers
I would think the condensor motor bearings are worn. Try testing for end play and side to side play of the condensor motor shaft, with the power disconnected.
Posted on May 05, 2015
1 Related Answer
Anonymous
SOURCE: I am a ac tech
you aren't an ac tech number one but i shall overlook that . your question is llike will the sun come up in the north or the south tomorrow. obviously in the east as it has since the earth was created. anyway. all compressors since the beginning of time wire up the same .a wire commonly referred to as the common goes from the contactor to the compressor. usually black in color, hence the old coloqualism Blacks are common. the run wire is from the contactor to the run side of the run capacitor or from the contactor to the run connection on the compressor. hence the old slogan reds run when you point a gun at them. the only wire left is the start wire that come from the start capacitor and is usually yellow . hence the old saying blacks are common, reds run, and yellows are always starting something. very ethnic i know but thats how i was taught.now that the wirings correct check to see volts through contactor are correct and if one side of contactor is not feeding. if volts good then check capacitors with a cap checker. if all else looks good kill power and inspect compressor terminals at compressor. if burned off consider a termilock kit good luck..
Posted on Oct 12, 2008
Display F3 on carrier Ac what problem
Well without a model number, I can tell you this. On some models, F3 indicates fan speed 3, which is high speed.If you push the mode button, these units will switch between f1, f2, f3 and smart fan. No problem.
On others, F3 indicates a fan speed error, either something is keeping the fan from turning, or there is a bad or loose connection somewhere.
On still other models, F3 indicates a freon leak or problem in the refrigerant circuit.
If carrier made their own units, they would probably act the same, but they don't. Model number is important, since the unit could be a daikin, LG or Samsung under the skin...
Nov 29, 2014 | Carrier Heating & Cooling
Horrible awful noise coming from carrier heat a/c wall unit!
I watched your video on youtube. Sounds like a seized compressor. Do you know if it is reverse cycle or electric heat?
Jan 18, 2010 | Carrier 52PQ307 Wall/Window Air...
Carrier AC 38CKC019 may have overheated. The fan unit buzzes but does not turn.
Hey there, ok, now if the fan is spinning and the compressor is buzzing, the compressor is locked up and needs to be replaced. If neither is running and the buzzing is coming from the control panel on the unit, it could be the contactor. Also there is a chance that the fan motor burned up, causing the compressor to fail so the fan would be off but the compressor is buzzing and locked up. If nothing is running also check the circuit breaker it could just be he conactor you are hearing. At that point you need to figure out why the breaker tripped. Let me know what you find out
seth
Jun 25, 2009 | Carrier 38CKC018 Air Conditioner
My carrier A/C turns off by itself but the light blinks
Switch OFF the circuit breaker of ac, after 5 seconds. Switched ON the circuit breaker. If this will appear again try to check the wiring connection of ac.
Jun 17, 2009 | Carrier 36KCARMS Air Conditioner
BDP furnace + model 585A030080YACR
Sounds like your indoor fan motor is not working, check either the cap or the indoor fan motor it's self.
Jun 26, 2008 | Carrier Heating & Cooling
Goodman CKL24AR24 Air Conditioner Logo
158 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
jdthefixer
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
