Question about Brother MFC-7820N Printer
Add model to Brother controlcenter4 - Brother MFC-7820N Printer
Why am I getting this message when trying to scan
It is not registered in your software, reload the drivers!
Aug 24, 2014 | Brother International Brother MFC-J4510DW
How do I fix this: Printing works but suddenly Scan function doesn't work?
I am a Brother employee working for the software technical support department.
We have a solution for your scanning issue posted on our solution site.
Description of Problem 100000024547
I am unable to scan in Windows 7 using the Wireless Network connection. What can I do?
Brother Software Technical Support
http://www.brother-usa.com
Jun 29, 2014 | Brother MFC7860DW AllInOne Laser Printer
I need Brother Control Center 4.0 for my brother DCP - 7065DN
the correct download is actually here. Click on this site: http://support.brother.com/g/b/downloadtop.aspx?c=ca&lang=en&prod=dcp7065dn_all
The page will automatically detect your OS version, just click on "Search" at the bottom. Then, select the first option which should be: Full Driver and Software Package.
At the bottom of the following page, click on "Agree to the EULA and Download". Then just run the installation, and restart your computer as requested once that's done. Make sure you disable any Firewall/Antivirus software before running the installation to make sure it goes through correctly.
Once your computer is restarted, everything should be installed including your ControlCenter4 software.
Hope this helps!
Jan 09, 2014 | Brother Office Equipment & Supplies
.install software
You can download the Brother printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.brother.com.au/ProductsSolutions.aspx
Oct 19, 2012 | Brother MFC 420CN All-In-One InkJet...
How to find a driver for a BROTHER MFC780N USB
Brother has the drivers and full software for supported OS versions for most of their printers on their web site. (Note: however, no third-party software that was on the original CD is available.) Start at: http://www.brother-usa.com/downloads/#.T49a0dm3NG9 and select Multi-Function Center and then the model number in the drop-down menus.
Unfortunately, I do not know the MFC 780 model. There is the MFC7820N and the MFC7840W (and others). Please check your model number and add a comment if this is the correct model number (or updating to the correct model).
I hope this helps.
Apr 18, 2012 | Brother Office Equipment & Supplies
Brother printer dcp 110c driver - WINDOWS 7
Brother has the solution for you on their website
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000043/faq002643_001.html?reg=us&c=us&lang=en&prod=dcp110c_us&Cat=102
In case you are in a hurry to install:
  1. Click Start => Control Panel => Hardware and Sound => Devices and Printers.
  2. Click Add a printer.
  3. Click Add a network, wireless or Bluetooth printer.
  4. Select the model name and click Next.
    If the model name is not listed, follow Steps i through iii and then go to Step 5.
    1. Click The printer that I want isn't listed.
    2. Select Add a printer using a TCP/IP address or hostname and click Next.
    3. Type the IP address of the Brother machine in the Hostname or IP address field, and check the Query the printer and automatically select the driver to use option. Then click Next.
  5. Select Brother in the Manufacturer list and click Windows Update.
    While the drivers are being downloaded, the Windows Update button will become inactive. It takes a few minutes to download the drivers. When the downloading is finished, the Windows Update button will become active again, and then go to Step 6.
  6. Select the model name and click Next.
    Note for HL-1030 and HL-1230 Users:
    The "Brother HL-1430" driver is the alternative driver for your Brother machine. Select the "Brother HL-1430" from the Printers list.
  7. The model name will be displayed in the Printer name field, and click Next.
  8. Click Next.
  9. Click Finish.
Have a great weekend!
Mar 05, 2011 | Office Equipment & Supplies
Brother MFC-7820N Printer Logo
151 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
