Question about Remington 10" Model Rm-1015p Electric Pole Saw Chain
What chain oil in RM1015P
What chain lubrication oil?
Dwight Beard
    Sergeant:
  • 333 Answers
Hello, The chain lubrication oil is called bar and chain oil. It is specially formulated to cling to the bar and chain to ensure maximum lubrication. You can obtain bar and chain oil at any hardware store or power equipment shop.
Posted on Jul 15, 2014
2answers
Lubricate has stopped flowing to lubricate the chain when in use. What should I do?
didnt specify make model ---generic answer--check level in tank ---if good remove cover, chain,and chain bar and look for a small foam sponge type material on inside frame along where chail and bar are thats what allows the oil to lube chain if covered in debris or clogged clean and or replace the following link showes the ioler on different models
Chainsaw Oiler Not Working Yahoo Video Search Results
Jul 12, 2016 • Garden
I have a still ts 510av it has a fuel (cap that says mix and one that says oil what kind of oil does this take
Its a special chain lubrication no other oil can be used to reduce heat dissipation of the chainring ,BUT BE AWARE reed? .
" The use of biodegradable lubricants takes interest
increasing. One liter of mineral oil can disable a million liters of water
make. In the form of lubrication (chain oil, lubricants oil and skin oil)
end up millions of gallons of oil in nature and are not there
aborted. It is therefore necessary to allow the use of biological
to promote degradable oil. In connection with the adhesion of the
oil pump (and the bar and chain) is biodegradable
Oil not recommended for occasional users of the chainsaw.
The oil is durable for years, if completed. "
How to stop flow of oil on to chain?
Interesting.
Chain lubrication
is critical to the life of the bar and chain.
I'd be suspicious that you may not be using heavy viscosity chain lubrication oil.
Light weight oil will flow much faster.
Dec 03, 2015 • Garden
2helpful
What Oil is used for the bar & chain lubrication
Hi khipiercy...
You will use "Bar and Chain Oil" for your chain and bar lubricant...it is specially formulated to be used on chains and bars of chainsaws...
You can buy it at any Loews,HomeDepot, Ace Hardware, etc.
Please take time to rate me
Misplaced the manual. Need to know what oil I should use for the oil lubrication.
The chain oil tank should have a non fling chain oil, the non fling addative is so the oil does not fly off the end of the bar and lubricates where most cutting is done.
1helpful
I have borrowed a chainsaw PWR1750CSA from a friend i need to know what oil goes in the tank, i presume it is to lubricate the chain.
The fuel tank takes a 25-1 fuel oil mix, the oil tank takes a non fling chain oil to lubricate the chain, if you you a light oil it will spray off the end of the bar and not lubricate the under side of the bar where most cutting is done, if you cannot get non fling oil use as thick an oil as you can get hold of.
Sep 08, 2011 • Garden
What type oil for chainsaw, both w/gas for fuel and also chain lubrication
You mix 2 stroke oil with the petrol/gas at a rate of 40:1 (40 parts petrol to 1 oil). For longer life use a good quality oil like Husqvarna or Stihl rather than the cheaper types you buy at car service stations.
The oil you use for the chain lubrication is just known as chain oil and can be bought at tool hire outlets.
2answers
What type oil do you need for an electric chainsaw?
you need to buy chainsaw lube oil, its red and lubricates the chain.chainsaw chain lubricant. plz rate-bozcro
It seems like the chain is not getting any oil earlier in the day the saw was fine. I had to replace the chain and started sawing on a tree and the chain just smoking and burning the wood. It does not look...
Are you using any oil in the oil resivour? The oil lubricates the chain on the bar. I would guess that you installed the chain backwards. If the chain moves freely on the bar it is getting lubrication. I have made that mistake before. check rotation and your new chain. Don't know what brand of chain saw you have, automatic oiler, manual oiler, ect. but would guess that the problem is with the chain itself. Hope it as simple as that.
Remington 10" Model Rm-1015p Electric Pole Saw Chain Logo
Top Remington Garden Experts
Phil Walker
Phil Walker
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Are you a Remington Garden Expert? Answer questions, earn points and help others
