Model odc
SOURCE: Black & Decker TCM700 Coffee Maker problem
the concept still applies. the heating element is usually dual functional. heating the water then keeping the plate warm.
SOURCE: black and decker spacesaver coffee maker
There are two heat stages in the Spacesaver. One is the carafe heater you can see while the other is an assembly within the main housing. This assembly contains a heater, thermostat, and a section of metal tubing with high temperature silicon connectors at each end. when the water storage tank is inserted it fills the heated section of the tube and when activated the water boils as it passes through the one way valve and forces the water into the coffee container. This steam driven surge repeats until all water has been moved to carafe. There are several failure modes associated with this assembly an I have two. 1. is the heater opening which I have and 2. is the thermostat degrading causing incomplete transfer and ultimately no transfer because it brings the temp down prematurely. Another is crud on the check valve so many problems - no solutions
SOURCE: replacement carafe for Black & Decker ODC325N Spacemaker 12-Cup
You can have mine for the cost of shipping
SOURCE: On but won't brew
The heating element may have failed or a connection has worked loose. Chances are slim you'd find anyone even willing to look at one of these. It would cost more to repair than replace.
SOURCE: no power on black and decker coffeemaker
Often you can find hard-to-find Black & Decker coffee maker replacement parts here: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=black+decker+coffee&submit=Search&_sid=93311479
