Question about Soyo Computers & Internet
Why has my monitor turned orange. model dylm19r6 computer monitor
Bob Sloan
  • Soyo Master
  • 2,013 Answers
If you mean the light on your monitor is orange instead of green, it means the monitor is not receiving data from the computer.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Posted on Jul 16, 2014
Dell optiplex light turns orange
Does anything ever post on the screen when you hit the power button?
Maybe the monitor is bad or the video card inside the computer is bad. Normally if the video card is bad the monitor will display a message of No Signal. If you are getting no message then I think your monitor is bad. To isolate the problem you need to put another monitor on the computer.
Borrow a monitor from a neighbor, friend, family member or co-worker and connect it to the computer. If the Borrowed Monitor displays and works, then your original monitor is bad. If the Borrowed monitor does the same as the original monitor then your video card is bad.
I have model 1975NW. When power is turned on, green light appears, then orange light. No picture is present.
The ORANGE light indicates "power-saving" mode -- when no "output" from a video-card is being detected, the screen will dim itself. Try a different monitor. Try a different video-card in your computer. Try your monitor on a different computer.
Monitor will not turn on? westinghouse model L2046NV black screen will not turn on what should I do?
Do you see an orange light on the monitor anywhere? Usually the light turns green when the monitor comes on, but its orange when in "standby" mode. If your monitor is plugged in and you get an orange light, that usually means that your video card has gone out on your computer. When your video card goes out, the monitor doesn't receive a signal from your computer, so it doesn't know it is suppose to turn on. So if this is the case, you need to replace the video card on your computer
If your monitor doesn't turn on whatsoever, and everything is plugged in correctly, then you need to get a new monitor or send this one back to the manufacturer for a defective replacement.
Hope this helps! :)
1helpful
WILL NOT LIGHT UP-COMPLETELY DEAD
Hope this helps! :)
Viewsonic VG700b bug
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
Dell monitor 152fpc orange coloring replacing red
If you connect the monitor to a laptop's "video-out", do you get correct colours, or do you still get the "orange" ??
If so, then the monitor is the problem.
NEC 17'' Multisync CRT monitor does nothing when turned on
the green is working ok but orange is usually waiting for an input from the pc (no input signal)
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Computers & Internet Logo
Top Soyo Computers & Internet Experts
Ekse
Paul Bade
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
