Question about Jacuzzi Home
WHY DOESN'T MY JACUZZI PUMP WATER UNTIL THE TUB IS FILLED TO AN INCREDABLY HIGH LEVEL? THE PUMP RUNS BUT NO WATER IS PUMPED UNTIL THE WATER LEVEL IS VERY HIGH.
JACUZZI - THAIS DESTRA S/FRONTALE
5 Related Answers
Anonymous
SOURCE: JACUZZI HOT TUB J365
MOTOR TO HOT TUB KICKS OFF ON HIGH SPEED AND GETS VERY HOT AFTER RUNNING ABOUT 20MINUTES AND STARTS BACK UP IN LESS THAN A MINUTE,BUT CONTINUES TO KICK OUT ,IVE REPLACED THE MOTOR AND STILL SAME PROBLEM..
Posted on Oct 24, 2008
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Jacuzzi jets not pumping out water
Check the jet pump, also where the filter is there are two 90s plastic. make sure that they are both in the water, if all those check out then check the switch for the jets. It sounds like the pump is bad and is not pumping the water. Even if the motor works and the internal parts of the motor seal gets wet then it all needs to be replaced and rebuilt. Very easy to do yourself. Like always be careful and unplug the unit.
Posted on Feb 11, 2009
Alan
  • 80 Answers
SOURCE: Jacuzzi Select model 10 years old. Motor
Sounds like the high speed relay is stuck or not working at all, It is in the main contol box, and can be manually tripped to see if this is indeed the problem. Unless you are a skilled repair tech, this job is better left to a pro.
Posted on Aug 19, 2009
Alan
  • 80 Answers
SOURCE: jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Posted on Sep 28, 2009
keith rodriguez
  • 15 Answers
SOURCE: my bathtub jacuzzi wont work. I reset the circuit
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Posted on Oct 04, 2009
Maax hydromax jacuzzi tub
check recirculation pump
May 10, 2018 | Pool & Spa
Water level sensor
The 'low-water' sensor installed in a bathtub is designed to NOT allow the pump to run without water contacting it.
It sounds as if this is operating as it should.
Once the pump comes on you should be able to touch the "logo" or the on/off button to turn the pump on and off.
If the pump is not turning on/off when the tub is full of water you may be experiencing a problem with the control box under the tub skirt.
Rod
US Parts Center
888-521-6183
Mar 20, 2014 | Jacuzzi Home
My jacuzzi Century Flex-48 pool pump is surgeing after running for 10 min.
possible motor overheating then overheating seals, then they wont pump water they expand and water goes by them
Oct 09, 2017 | Pool & Spa
I have a kohler jacuzzi tub and many times over the past 5yrs the pump continously trips and the jacuzzi will not start. Any suggestions i have tried to reset the button unplug and plug it, an filled it...
Sound like your pump may have a leak into the electric motor part of it through the shaft seal.
Or it could just have junk stopping up the lines or the pumps impeller. Hair often finds it's way into these things and screws them up!
If it's leaking there will be some water showing below the pump unit.....
Feb 20, 2011 | Kohler Home
I can see outside of tub get wet and it leaks by the drain..its brand new..only does it when its drained after being filled to a high level..is it cracked or something? can't see any but dont know what...
If it only leaks when filled to a high level, the rubber washer behing the overflow plate is misaligned or missing. this plate is on the tub wall above the drain, and hld in in by 1 or 2 screws.
Oct 05, 2010 | Jacuzzi Home
Is leaking water at the back and running in the floor the hoses are tight drain pipe is in right
Here's what I've seen. Water will be full, machine goes to spin/drain and expects the water to be pumped out as predicted. If pump is clogged, the pump cannnot pump out water quickly enough and the spinning causes the water to spill over the back of the tub, between the tub and balance ring. The balance ring is never sealed tightly to the tub so water will get through. Fill the basket with water, extra high, hold lid switch down, and see if it drains out fast enough so water doesn't spin out. If this is the case, pull pump, dislodge debris.
Oct 02, 2010 | Maytag Washing Machines
Our A O Smith pump/motor gets airbound everyday
Well somehow air is obviously getting into the pump line. Easiest fix is to move the pump below the water level of the tub and then gravity will keep water in there. If you do have the pump below the water level, then make sure you don't have jets shooting a bunch of air directly at the intake in the tub. If that's not the case and it is below water level, then make sure you don't have a leak in the line somewhere.
Jul 19, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Jacuzzi nova 532 motor run's but won't stay running
If it has the little oval off/on button, it sounds like the control box or off/on button is bad. If you have access to the pump assembly, follow the pump power cord to the little black box (zip tied to a tube up high), this black box has a small cable that goes to the off/on button. unplug the pump from the box and plug the pump into the power outlet. it should run continuously. If it runs, you need a new control box or /offon button. Buy the off/on button first, as this button is prone to water getting into it, and costs less than the control box.
Mar 25, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jets are draining my jaccuzzi tub
Check to see if there is an open valve where the water exits the tub. If there is a valve, shut it and your problem should be solved. good luck
Jan 15, 2009 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Home Logo
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
