Question about Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator
How do i remove the base plate from my whirlpool french door refrigerator?
4 Related Answers
Anonymous
  • 22 Answers
SOURCE: light clicking sound from outside whirlpool french
Check the fan blade on the fan in the freezer. It could be an object or ice, frost, anything. If this is an Amana Whirlpool, definitely check to see if the fan blade is no longer tight on the motor shaft and has moved forward and hitting the guard in front of it. ( yes, amana whirlpool )
Posted on May 12, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: how do you remove the face plate the is on the
Remove the top hinge cover , covering the top freezer door hinge , and unplug the visible receptical . This removes power to the dispensor and dorr . Using a butter knife between the grill and the dispensor bottom cover , push down and inward , prying the cover outward . Do this on both sides , about 1 " from each side . This pops the plastic clips off . Raise the cover to release from the upper plastic retainers . Disconnect the plug from the cover and its removed . Do this carefully , because your working with plastic . To reinstall , reconnect the plug to the dispensor cover , slide the top in place and pop the lower tabs back into place . Reinstall the top hinge plug and cover .
Posted on Aug 30, 2009
milten1
milten1
  • 1304 Answers
SOURCE: I have a Whirlpool Gold refrigerator w/french
you might be able to get a little room
look at the bottom hinge of the door
the one you want to lower
you should see a few spacers between
the bootm of the door and the top of the hinge
as well as being able to lower the hinge pin by screwing it down
Posted on Oct 11, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: 2009 french door refrigerator whirlpool gold water
It appears your dispenser mico switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Whirlpool french door refrigerator not making ice
Is it receiving water. Try removing the icemaker and thawing it and reinstalling. Of course pleaz check the shutoff arm as well.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Mar 01, 2018 | Whirlpool Refrigerators
Water filter in whirlpool refrigeratoris stuck and cannot be removed
http://www.partselect.com/Refrigerator+whirlpool-filter-removal+repair.htm
Aug 26, 2016 | Whirlpool WRF736SDAM 26 cu. ft. French...
WHIRLPOOL REFRIGERATOR FRENCH DOOR ENERGYSTAR 5 MO OLD SAYS COOLING SYSYEM OFF ?
STOP! Don't worry about the other responses- it is SO simple to fix. You just press the two right two buttons (lock and measured fill) at the same time and hold for 3 seconds. That's it!!
May 23, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Whirlpool stainless french door refrig...need to take handle off bottom freezer door so I can move it out of house. Is this possible without taking off the whole door?
it is much better to remove the complete door instead of handle . there are 4 screws inside that will release the complete door . if your want to do the handle use a credit card and insert it between the handle and door to release . but if stainless it some times leaves marks on door . i always remove the doors as one door is ever and i mean very costly.. mm hope this helps mm feed back pls ..
Nov 08, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
I want to adjust the upper doors on a viking french door model vcff036ff. The left door is higher than the right door. It appears that I have to remove the door to adjust it. Dan
USE A SPIRIT LEVEL ON THE OUTSIDE OF THE UNIT FIRST,IT IS POSSIBLY THE FLOOR THAT IS NOT LEVEL.........USE SPACERS UNDER THE FEET......factory build them square.....
Jun 07, 2010 | Viking VCFF036 Bottom Freezer French Door...
Remove Faceplate on fridge
I am have the very same problem. I removed the dish beneath the water/ice dispenser, and located two small screws. These two screws appear to hold the bottom of the face plate to the door. I removed them. However, the faceplate still did not come loose. I suspect there are more screws or clips toward the top.
Nov 20, 2009 | Whirlpool GI5FSAXVY Stainless Steel ...
We have purchased a water filter for our Whirlpool Gold (French door) refrigerator, but don't know how/where to install it. Can you help us?
Most all Whirlpool refrigerators with a filter have the filter at the base where the 'kickplate' grill is. Simply turn it counterclockwise and pull it out. Reverse procedure to install new filter. No need to turn off water or anything like that. If you have a water filter light that requires resetting, press down and release the light switch 5 times within 10 seconds.
Sep 12, 2009 | Refrigerators
Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
