SOURCE: Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
SOURCE: aficio 1018d
Try this you will have to enter service mode
clear modes(yellow button@ top)-1-0-7- and hold down the clear/stop button until the screen changes saying service mod, after that, while machine is still displaying service mode turn the machine off and then back on( don't use the MAIN POWER button on the operation panel just unplug the machine and plug it back in) This should reset the code. The code may reappear if there is a problem with the machine but 90% of the time they start working Good luck
SOURCE: RICHO AFICIO 650 SHOW ERROR 890
The code 890 do not exist like 880 but, if it is 980? the problem can be in the hard disc...
Incorrect parameter sent to the HDD controller.
First try
reset the software… press the point and numeral
key simultaneously until automatically it is off the copier, several seconds can
pass, the copier back on automatically. The software will
have been loaded again.
If the problem persists it proves with another
hard disk,
since the
other possible solutions already are more complicated; these are:
· Software defective
· SBICU defective
Another
problem that sometimes cause erratic errors in these copiers is that it has
fallen develop in some sensor having caused short circuits that annul to some
times some voltage of the power supply interrupting processes indispensable for
software. Example “by developer in the ID sensor” the copier scanned but nothing more. Developer in the sensors of the feeding units produced a code 322 can
seem incredible but it is thus.
For it
would recommend a deep cleaning of the sectors of the image unit and everything
what is under the development unit.
SOURCE: I have a richo copier
you can change. You have a door right in front of the equipment. If you open that door you see the toner bottles. You pull the old one and then put the new bottle
Testimonial: "Thank you so so so so so much. You have solved my copier drama. Thanks so very much"
