Question about Hitachi 61SDX01B 61" Rear Projection Television
How do i hook up external surround on hitachi 61sdx01b
I hooked up a sony surround sound, and it wont play through speakers
4 Related Answers
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: external speakers
Enter your TV model number in Hitachi Manual page and find required user manual.
Posted on Oct 01, 2008
Anonymous
  • 2920 Answers
SOURCE: No Volume from the set
you will need to go under the settings for your tv and find the volume control and reset it to internal dpeakers and take it off of external.
Posted on Feb 07, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: hi my hitachi 61sdx01b red power light is working
CK fuse F903 if it blows it again then replace STRM6511 CK all of the pico fuses 5and 6 amps they look like resistors they willbe green or yellow they are fuses.
Posted on Dec 21, 2009
jimedington
jimedington
  • 39 Answers
SOURCE: can I hook up my 32fx48b hitachi tv to a surround sound amp?
Can you clarify? Are you talking about just an amp, or an a/v receiver? In short, the answer is yes, but some amps/receivers have limitations on what inputs/outputs are available.
Posted on Jan 15, 2012
Sony bravia 285 and xbox surround sound.
a HDMI lead has sound and video cables
Jan 11, 2010 | Sony Electronics - Others
Hitachi 61sdx01b rear projection has no audio at all.
If no sound in all input, check the surround board. Is the audio distorted or on and off before? if so replace surround board :)
May 27, 2009 | Hitachi 61SDX01B 61" Rear Projection...
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
Attaching a surround sound to a Hitachi 60CX29B
the red green and blue are component video
to get the surround sound to work the red and white audio outputs from the tv go to the audio inputs on the reciever , and to get the digital surround sound the optical also has to be hooked up
Nov 06, 2008 | Hitachi 60CX29B TV
No sound from back speakers
Remember the rear speakers are called surround... Did you select surround on the unit? if it says stereo then you will only get fronts, select surround to get the rest.
Jul 13, 2008 | Sony STR-DG510 Receiver
Hooking up surround sound
do you need a reciever to get ceiling mounted speakers to work surround sound
Jul 11, 2008 | Audio Players & Recorders
How to hook up surround sound
Check in the TV audio menu adjustments to activate the audio going out to the external speakers.
Hope it works.
Feb 08, 2008 | Hitachi 51F510 51" Rear Projection...
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
Hitachi 61SDX01B 61" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Paul Bade
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
