You might try resetting the device. See this site... http://www.howtogeek.com/130611/how-to-factory-reset-your-android-phone-or-tablet-when-it-wont-boot/
SOURCE: when turn on monitor screen flickers
This usually indicates a power supply that is about to fail. Heat buildup in the
monitor case causes parts called capacitors to overheat and blow out.
Check out our web site at: www.ccl-la.com/badcaps.htm
We have pictures of what the blown capacitors look like. Open the back
of your monitor and look for the blown caps. Replace all the ones that
look like the ones in the pictures and you should be back up and
running. We are working on a step by step repair guide that should be posted on our site by the end of the week. The values you need to get are going to be marked on the sides
of the ones you take out. Be sure to reinstall the new ones with the
polarity stripe going the same direction as the old ones come out. You
can order replacement parts from several places on the internet or we
can supply them for you. You will need to use high temp caps that will
be marked 105c, these are not available from Radio Shack. If you use
ones that are not rated correctly then you will have more issues in a
month or two. If you don't want to do the repair yourself we do offer a
repair service for $35 plus return shipping.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
SOURCE: how to reset zeki tablet
THERE ARE THREE WAY THAT I NO TO RESET THE ZEKI 7" TABLET FIRST: IS A FACORY REST WHICH IS DONE BY THE RESET BUTTON ON THE BACK OF THE TABLET. PRESS AND HOLD 30SECONDS. 2ND IS A SOFT RESET HAT IS DONE FROM SOFTWARE ON THE TABLET.IN THE SETTINGS. THIRD IS A HARD REST WHICH IS DONE FROM TABLETS, KET, VOLUME, + VOLUME-, AND POWER BUTTONS. NEW ZEKI OWNER ELJAYP.
