A copper colored fuse of some sort has fallen out from under my brake petal it does not go in the fuse box and my car will not go into gear.the fuse is a copper colored says T1 at the top then 12v 20a 042
Brake must be depressed to put car in gear. Sounds like the switch that tells car that brake has been depressed has broken. Change that switch and car should go into gear.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Many of these require that you apply brake n order to put it into gear. Fuse probably is in circuit for brake pedal to let control unit know you have foot on brake. It is likely that the in-line fuse holder has broken (quite common) and thus the fuse fell out. Remove any under dash panels as needed to be able to see into this area, and you should find a wire with a part of broken fuse holder attached. Find the two ends and splice in a new fuse holder and fuse=fixed!
