Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do i get picture back ?
Sound only cannot see anything at all menu etc
Posted by Jim Ferry on
Olevia 242-S11. Have to turn tv off and on 6 times before sound stays on. No problem with picture.
Menu , sound settings, disable all special effects , Dolby surround, stereo, etc.. unplug, Wait overnight plug back in see if the problem continues if so, check sound settings they should be the way you left them
Aug 10, 2016 | Olevia Televison & Video
Sony KDL46S4100 when turned on there is no picture just a blue screen
Is this blue screen on all inputs (HDMI, etc.), or just on the one?
Does the remote control work, can you get the menu to display, is there any sound?
If no sound and picture, no menu etc., might be a software problem, the main PCB, or a missing voltage on this board.
Feb 24, 2015 | Sony KDL46S4100 Bravia S Series 46" 1080p...
No Picture or sound on my JVC HD-56FN97 Television
No, if bulb is bad you will not see anything on screen.
Are outside sources connected to different inputs on TV?
Apr 13, 2014 | Televison & Video
Akai tv picture no sound
If picture is OK, sound should be there. Check the settings to sound first, ie, 'system' 'mute' etc, by entering the sound menu. If an improper system is selected, the sound will be either absent or distorted. If all the other settings are OK, and still there is no sound, you have to check the audio output section circuit, speakers etc?
Jul 19, 2013 | Televison & Video
Lightning struck and now no picture on my tv- sound works tho
I think the digital input selector section has got affected. I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation.
Aug 16, 2012 | Televison & Video
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Was watching TV and the picture just went black (still had sound)
eithor the flyback just craped out or the tube went
try turning up the flyback failing that call a service tech and ask for a quote
quote cose 30-50 bucks
atleast you will know forsurre if it's worth fixing
Aug 06, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Picture very dark
try to adjust the screen at the back of the plyback.a big parts inside the tv with a wire attach to the picture tube. thre's a two knob there, the lower knob try to adjust it
Oct 09, 2008 | Sylvania 6432GG 32" TV
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
