Hello, i have an hp color laserjet 1600 and the laser beam was dusty but it was working so i open the machine wipe the mirrors then the machine started showing door open message. i try everything by even changing the board on which you the door switch but the message is insisting
SOURCE: hp laserjet 2600n printer showing message door open
there door censer problem. i fix new censer
SOURCE: red color on hp 1600 not work fine
1. Turn off the printer.
2. Press and hold the (Select) and (Cancel Job) buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init displays, release the (Select) and
(Cancel Job) buttons.
When the NVRAM init is complete, the printer will return to the Ready state.
SOURCE: Cleaning mirrors on HP Laser 1600
The printer does not have mirrors if your talking about the lasers they are situated behind each of the toners through a long gap hope this helps.
SOURCE: HP color laserjet 1600 wonte printe new toner color.
The supply status report is based on what the kill chip is reporting to the printer. If that particular color is not printing then it is likely that current is not flowing though a particular component in the cartridge. I would return the cartridge and get a replacement.
SOURCE: My Printer HP 1600 Laserjet error 10.1001
Did you fix your problem? I have the same one. With Hp 2600N
All cartridge are new, and i removed the orange tab from each one.
I even tryed a second new cyan.
Did you remove All the orange tab from cartridge?
